05-24-2022 02:31 PM
The lcd on my eos 5d mkiii is suddenly not working properly. It displays the menu, info, Q button, and images. It will not display wb, af, iso, or af point select from the buttons on the body like it used to.
05-25-2022 04:22 AM - edited 05-25-2022 04:23 AM
Under the third screen in the Wrench Main Menu, if you select INFO button options, what is set there? If not all, then check all of the options, and then when you have returned to the normal operation mode, does that work now with repeatedly pressing the INFO button?
05-25-2022 08:01 AM
Are you perhaps in an SCN or icon mode that doesn't allow those settings to be changed?
05-25-2022 10:47 AM
I had looked at that previously. All 3 options were checked. For giggles l unchecked the first 2, the 3rd would not uncheck. Fixed! Thanks so much!
