EOS REBEL T7 Built-in flash might not work
gestewart65
I have a new Eos rebel T7. Not sure built in flash works…. Can I reset factory settings?
Actually found the hot show cover was engaging switch. Removed and all ok for now
4 REPLIES 4
rs-eos
Is the camera in manual mode?
To reset your settings, bring up the third wrench menu (right-most of the wrench menus), scroll down to "Clear settings" and select it.  You'll have a choice of what to clear including the ability to clear all camera settings.
See page 194 of the User Manual for details.
Ricky
deebatman316
Hello gestewart65 are you sure the built in flash doesn't work. On certain Rebel series cameras you must manually pop up the flash even in Full Auto mode. In order to pop up the flash you must push the flash button that is located behind the main dial.
-Demetrius
EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 28-135mm F/3.5-5.6 IS USM (Retired), EF 50 F/1.8 STM, EF 85mm F/1.8 USM & EF 70-200mm F/2.8L IS III USM
EOS 40D (Retired) & 5D Mark IV
430EX III-RT, 470EX-AI & 600EX II-RT
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Friends and Family
