02-20-2024
09:58 AM
10:00 AM
I am having a problem getting one of my R6 cameras to display the video screen when the camera is dial is set to video. The other camera displays the correct screen. Any thoughts?
02-20-2024 10:11 AM
The right-hand camera appears to be in custom shooting mode 1. Are you sure that both cameras are set the same way?
02-20-2024 04:21 PM
Ricky is correct. The right camera is set to a Custom Shooting mode.
See page 755 in your manual:
02-20-2024 10:11 AM
02-20-2024 02:53 PM
Yeah I think so. I have the mode dial on video on both.
02-20-2024 04:21 PM
02-20-2024 06:05 PM
Is that 50mm the f/1.4? Also, does it produce the same results when on the other camera?
Newton
02-21-2024 02:29 AM - edited 02-21-2024 02:30 AM
The rear screen views do. Indicate that only one camera is in video mode. I do not believe Custom Shooting Modes support Video Shooting modes.
Was the camera in video mode when the Custom Mode was defined
What happens if you switch the camera indicating a custom to another Creative Shooting mode other than a custtom mode?
02-21-2024 04:33 AM
Is it possible there is a fault with the mode dial?
I would try each of the positions that the mode dial can be set to and check that the LCD screen shows the correct mode for the position of the mode dial to see if other positions on the mode dial are also giving odd results.
