11-03-2025
10:03 PM
08:38 AM
Recently, when my R6 Mark II is powered off, I noticed it will power on for about 1 or 2 seconds and then power of again. This happens about every 20-30 seconds. The only way to stop it is to take the battery out. It may be a coincidence, but I think this started after I upgraded the firmware to v1.6.0 several weeks ago. It does this enough that it will completely drain a fully charged battery in about 48 hours.
Any thoughts on what is happening?
Steve
11-04-2025 03:50 AM
Do you have Bluetooth switched on? With Bluetooth on, the camera keeps the circuit live to allow the camera to be accessed from the Camera Connect App. I have been able to get the photos from my powered off camera in my camera bag using the app on my phone.
11-04-2025 07:06 PM
“ I think it's been on for years, but never caused a problem. I wonder if the latest firmware version is making it act that way. I'll sure check and see. “
Your issue seems to be unique. So I doubt the firmware update has anything to do with it. But we have had a few posts about cameras locking up for no apparent reason. These issues pre-date the release of R Series cameras.
The issues seemed to coincide with the inclusion of Wi-Fi, and later on Bluetooth, integrated with the camera bodies. Smartphones are always hunting for a connection. They seem to find cameras and cause the camera to seemingly lock up.
it’s best to disable all wireless communications if you are not actively using them.
11-04-2025 03:50 AM
11-04-2025 09:06 AM - edited 11-04-2025 09:08 AM
This caught me with my R5 until I read the manual section on the WIFI. Now I take the battery out when I am done for the day just in case I forget to turn it off. 🙄
11-04-2025 04:37 PM
Hmm. I'll check that. It's probably on, but has never caused a problem in the past several years. I guess something may have changed in the latest firmware that is causing it to act that way.
Thanks for the tip.
Steve
11-04-2025 04:38 PM
Thanks for the advice.
Steve
11-04-2025 07:06 PM
