EOS R5 shutter speed won't go higher than 1/250
belladeutsch
I have the Canon RF 24-70, f2.8 L IS USM lens.
I shoot in manual, but I find I cannot go higher than 250 on the shutter speed. Any ideas why this is so?
13 REPLIES 13
Stephen
Moderator
Moderator
Hey there!
Which camera are you using?
Canon R5
There are  two possibilities:-
  • You have a Speedlite on the hotshoe and it is switched on. This limits the shutter speed to the camera's sync speed which is 1/250, unless you use high speed sync mode.
  • You have configured the custom function for Set shutter speed range - it's on the C.Fn2 menu page. If there is a blue star next to the entry on the menu there's some limitation set.
Brian
Thank you, I will check.
I have a trigger on my camera for a strobe. Can that be it?
Yes the maximum flash sync is 1/250th. So to use flash with higher shutter speeds you need to use HSS/ FP flash. But at the cost of less power because the flash now has to pulse to avoid the shutter curtains from being visible.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
how would I set the flash to work in HSS mode, so I can go higher on the shutter speed?
Are you using a Canon speedlite if so what model. If its a newer Canon Speedlite released in or 2007 it can be set from the camera's External Speedlite Control Menu. If its an model it will have to be set from the speedlite itself. Newer models can be set from BOTH the External Speedlite Control Menu or directly on the Speedlite itself. If from the camera set it to the lightning bolt with H icon.
Flash Function Settings screenFlash Function Settings screenFlash Synchronization Set it to the one with 3 triangles and retestFlash Synchronization Set it to the one with 3 triangles and retest
-Demetrius
@belladeutsch wrote:
There is a little info on page 176 of the advanced users manual, but to me, it's a little vague.
So, attach and turn on a compatible flash. Go to the shooting 2 menu and ensure that "Flash firing" is enabled. Scroll down to "Flash function settings" and press "set" (or tap it). Now select "High speed synchronization", it's the icon with a lightning bolt and "H" beside it. You will get 3 options in the next menu, First-curtain sync, Second-curtain sync, and High-speed sync. Select the latter and you are good to go, provided your flash is compatible. I use a Canon 600EXII-RT on my R5.
Newton
Thank you!
How about when I use my Flashpoint strobe?
