10-13-2023
10:21 AM
09:30 AM
Hi I would like to know if there is any record formats that get locked using a ef lens on the cameras R5 and R6 II, i can't find answers when searching on google. I pretty much need at least 1080 60p to go forward with purchasing 1 or the other. Thanks in advance!
10-13-2023 11:13 AM
General answer
No, using an adapted EF lens does not "lock" or preclude you from using a specific camera setting or resolution.
However, some lenses perform better than others for certain operations. Typically video. With 3rd party lenses, compatibility and performance is not guaranteed.
The user guides for either camera will list any known compatibility issues. In general, however, you should expect good performance if using Canon branded glass with a canon branded adapter.
10-13-2023 11:31 AM - edited 10-13-2023 11:32 AM
"... using a ef lens on the cameras R5 and R6 II,..."
If you are purchasing a new R series camera buy R series lenses. That only makes good sense.
It is the camera that sets the record settings not the lens. That's probably why your google search didn't return anything.
10-13-2023 12:53 PM
Not sure if I fully understand the question. My gut says that there should not any correlation between video recording formats and lenses.
However, there are limitations between video recording features and modes with certain EF lenses. Some EF lenses are not fully compatible. There should be a listing of fully compatible lenses in your User Guide. Stick to STM zoom lenses released after 2009.
It is a safe bet that some third party lenses are not fully compatible with features like Movie Servo AF, too. Canon does not keep track of which lenses work or don’t work. I expect that most of them would not work, at least not very well.
10-14-2023 10:42 AM
For the EOS R5, the answers are in the manual. If using an EF-S or RF-S lens, then some record formats will not be available. When using an EF lens with a Canon adapter, then all are available. Storage media speed may make some of the highest data rate recording formats unavailable, so it may be necessary to purchase a faster memory card. The manual lists what video formats are supported for the various card speeds.
https://cam.start.canon/hy/C003/manual/html/UG-03_Shooting-2_0040.html
