08-05-2022
04:23 PM
08:11 AM
My new MP4 videos I am shooting with my R5 are not being displayed by my computer programs such as media player or Movavi etc. Video I shot last week on this camera is working fine. I have been playing around with my settings as I am new to video. Could I have switched some setting to have caused it? They are all listed as MP4 and as stated, existing MP4 files on my computer from this camera are working fine. The new files are playing back fine on the camera. Current settings are 4K-U, 29.79, ALL-1. I have tried some other configurations but am getting similar results.
08-06-2022 03:11 AM
Sorry I don't have much help. I have tested all the R5 modes and the MP4s play fine on my computer (Windows 10, VLC media player).
Did the files maybe get corrupted when you copied them over? I have an external card reader which sometimes does this.
Check the file sizes -- are the realistic?
08-06-2022 08:42 AM
Figured it out. Somehow, the Canon Log became enabled. Don't remember touching that but once I disabled it everything worked fine. Thanks!
08-06-2022 12:31 PM
I'm glad you're up and running; but I think you may be on the wrong track there. I shoot nothing but log on the R5, and I've never had this issue. So if it happens again, you might want to look into other possibilities.
08-06-2022 12:55 PM
Thanks but so far so good!
09-01-2022 12:54 PM
I had the same problem. Found the solution. Uninstall your current version of VLC. When you try to update it within the player, it will tell you you already have the latest version. You probably do not. You need version 3.0.17.4. After you uninstall your current version of VLC. Go here: https://www.videolan.org/vlc/ and install the new version. The 4K files still don't play great (depending on your editor) buy you can at least see them.
09-01-2022 12:55 PM
If you want to use Log settings and still view them on your computer, follow the directions above.
02-18-2025 11:34 AM
A simple solution is to use VLC media viewer to convert MP4 to MP4 files. Can use in batch mode. Then he MP4 files load in most programs.
