R5 II - Is it possible to back up the "Save my camera settings" .CSD file?
Fotocb
I've connected my R5 II to my computer to back up the "Save my camera settings" .CSD file, but as I go through the various folders and subfolders, I just can't find the "CAMSET**.CSD" file.
Note that whenever you format your card, the CAMSET**.CSD" file(s) is deleted and gone.
FYI, I run WIN 11 pro and I have made sure in Folder explorer to set the options so that I can see hidden system files and folders.
If you have succeeded, I would really like to know how to do that backup.
If you connect the camera to the computer with a USB cable, you cannot see the .CSD file. It is only visible if you use a card reader and remove the card from the camera.
When you save a camera configuration to the card using the camera menus, the file is saved on the current primary card. So if your camera is setup to read / write to the CFexpress card than that is where the .CSD file goes. And vice verso if you have the SD card as the primary card.
Brian
8 REPLIES 8
jrhoffman75
The .CSD file should be in the root file of your card. I copy the file to a folder on my computer and reload onto the card after I format the card.
R6 Mark II, M200, Many lenses, Pixma PRO-100, Pixma TR8620a, Lr Classic
Fotocb
Thanks for your reply. Now I know it can be done.
Are you using a Mac or a PC?
Would you mind posting a screen capture of your computer/laptop screen including the path in the address bar?
I would find it really helpful as I really can't find the .CSD file.
The .CSD file will be in the root directory where the DCIM and MISC folders are.
March411
I do the same as John, write it to the card then copy to a directory on my PC. Here are the instructions from Canon manual. Pretty straight forward with screen shots.
https://cam.start.canon/en/C017/manual/html/UG-07_Set-up_0310.html
Marc
Windy City
R3 ~ R5 ~ R6 Mk II ~ R50
Lenses: RF Trinity and others
Adobe and Topaz Suite for post processing
Personal Gallery
Thanks, John.
My last 2 questions:
- Is that file to be found on the CF express card only and/or the SD card?
- Do you use a CF express card reader or do you connect your camera directly to your computer via USB-C connection?
My R5 MkII Folder Structure.jpgJohn, here's the folder structure (in tree view) of my R5 MkII (with the latest firmware 1.1.1) when connected to my PC (WIn 11 Pro).
As you can see, there is no .CSD file in the root file.
The content of the SD card is exactly like that of the CF Express card
Each card has 4 folders, and three of them are empty. Only the DCIM folder contains the image files.
What do you make of that?
jrhoffman75
I don’t have an R5 so can’t help. If no one else responds give Canon support a call at 1-800-OK-CANON.
Brian
Holiday
