Wi-Fi won’t activate even when enabled on Canon 5D Mark IV
Ilhemn11
Hello,
I’m having an issue with my Canon 5D Mark IV. After connecting the camera to my computer via USB to copy photos and then unplugging it, I try to enable Wi-Fi (Menu → Setup → Built-in wireless settings → Wi-Fi/NFC → Enable). The option lets me select “Enable,” but Wi-Fi never actually turns on, it remains off.
I have already tried:
- Clearing communication settings
- Clearing all camera settings
- Removing the battery for an hour
- Re-entering a new camera nickname
Has anyone experienced this before? Any advice would be greatly appreciated.
12 REPLIES 12
stevet1
IIhemn11,
Is your Airplane Mode off?
Steve Thomas
Older DSLRs such as the EOS 5D Mark IV don’t have airplane mode.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Hey Steve, there isn't a direct "Airplane Mode" setting in the same way there is for newer mirrorless cameras, for the 5D Mark IV  disabling Wi-Fi/NFC achieves the same result of temporarily disabling wireless functions.
Demetrius,
Huh. I didn't know that.
Thanks,
Steve Thomas
Does the EOS Rebel T8iEOS 850DEOS kiss X10i have that setting. I know that EOS R series cameras have this setting. But I’m not if the EOS M series has this setting along with other EOS DSLRs.
-Demetrius
Demetrius.
You wrote, "Does the EOS Rebel T8iEOS 850DEOS kiss X10i have that setting?"
If you are talking about Airplane Mode, I have a T8i and yes, it does.
Steve Thomas.
IIhemn11,
Aside from turning off Airplane Mode, I'm not sure I can help. It's as if your camera still thinks it's connected by a cable.and won't let you connect by wi-fi/
Perhaps you could try turning your camera off after you disconnect the USB cable and start wi-fi from scratch.
Steve Thomas
I’m surprised by that.
-Demetrius
nathaliebauer
Hello, I'm experiencing exactly the same problem, did you actually find a solution for this ?
