04-05-2026
08:49 PM
09:01 AM
Getting back into playing with DPP4 (still a newbie with it) and wanted to play with Dual Pixel RAW Optimizer. When I click on it in the Tools menu I get "Target file does not exist." I was working with a RAW image from a R5, if that is the issue.
I didn't find a whole lot on the Support page, but AI (which, of course, we all believe whole heartedly) said to reinstall. So download again from the Canon site and did a clean install with no change.
I don't see it on the site as a separate download, so what am I missing?
ADDED: I discovered that you have to Activate the option in Customize Toolbar (which doesn't makes a lot of sense🤔). But that has been done with no change.
04-05-2026 09:15 PM
04-05-2026 09:15 PM
Did you turn it it on in the camera for the raw you took?
04-05-2026 09:21 PM
Ohhh... Okay, back to the camera to check. Didn't realize it was a setting in the camera that would be defaulted to off.
04-05-2026 09:43 PM
It is in the first shooting menu with the image quality
04-06-2026 05:05 PM
There are some caveats and tradeoffs when the option is turned on:
04-08-2026 12:23 PM
Thanks for the notes. I've been reading a bit about it and when or if I'll opt to use it.
Originally I didn't remember reading about it on the camera side and just ran across the option in the DPP menus. But obviously not just a DPP thing.
