EOS R5 Mark II turns on between the switch is “off” & “lock”
Haiger2025
My camera will be turned on before the “lock” position, even only 1-2mm away from the “off” position. Is this normal? EOS R5 Mark II
Haiger2025
To all the friends who care about this issue:
Today, I went to the official maintenance center and looked at their prototype r5m2. I found the same situation, which shows that it is not an individual “problem” and is no longer a "problem".
Thank you again for your patient answers and solutions. Wish we all have better lives and create more beautiful moments with our machines.
12 REPLIES 12
Haiger2025
If you happen to have this product in your hand, can you try it for me? Push slowly from the off position to see if it will be opened in advance from the lock position.
rs-eos
Yes, that seems to be the case. But in practice, since there's a decent amount of resistance on the switch, the odds of someone slowing moving the switch towards the on position, then changing their mind and moving back, would effectively be zero.
Ricky
Sir, you’re right. I might be “too strict” to the machine. But it is a little bit strange that the machine can be turned on before the “lock” position. Maybe… It’s a design by Canon🤣 Anyway, thank you for your attempt and reply!
“ Sir, you’re right. I might be “too strict” to the machine. But it is a little bit strange that the machine can be turned on before the “lock” position. Maybe… It’s a design by Canon🤣 Anyway, thank you for your attempt and reply! “
If switch doesn’t stay in place when you let go of it, then what difference does it make?  My advice is to stop doing that before something bad happens.
My point is, that area before “lock” is not supposed to be the place where I can turn on my camera. According to my use, when I let go and the switch will stop in the middle before “lock” and keep the power on. I did see a user with a more serious situation than me. He could turn on the camera with a slight press on the switch, so he go to repair it. If most of us have the same situation, then maybe is a design by Canon so there’s nothing I should worried about. If others don’t, then I have to go and repair it too. Anyway I will accept your suggestion and thanks for your reply too.
I am having a related issue with the on off switch. (R5 Mark II - Less than a week old, won't stay turn... - Canon Community) the camera keeps turning on randomly even while the switch is in the off position and pressing it farther to the left turns it off. so perhaps our issues are related and the switches for the R5 Mark II are not aligned properly.
themikeinator
If you can return it and exchange it for another I would. Its seems to be a similar issue what I am dealing with where the switch wont turn the camera off. I would hate to see your issue get worse with time. (R5 Mark II - Less than a week old, won't stay turn... - Canon Community)
FloridaDrafter
My R5 II doesn't do that. No mater how slow I switch it, it doesn't power on until it hits Lock.
Maybe yours is a hair out of spec.
Newton
Maybe we are experiencing the same "switch problem", which shows that I am not the only one who has encountered the problem. That would be Canon’s problem, so I'm going to repair it. If there's really a problem, they may not give me a new machine, so the brand-new machine is about to be disassembled. And that is really heartbreaking...
