06-24-2015 09:13 PM
Hello there, I have a Canon EOS 600D and I've been having issues with normal focus. It is completely out of focus, even if I try to adjust it manually and at normal zoom, on the frame are black edges around the corners. I don't understand what's causing this, I've tried thoroughly cleaning it and everything but nothing seems to fix it. However, if I use a wideangle lens on top of the standard lens, the focus is greatly improved to how I supposed it normally should be but again at normal zoom, the black edges are ruining the image.
It would be greatly appreciated if I could get any help! Thank you! 😄
06-27-2015 09:52 PM
Whatever that piece of junk is on the front of the lens, remove it. It may have damaged your lens. If it did Canon will not warranty the lens.
I would return the whole outfit tomorrow. Then go to B&H or Adorama and buy the real deal. Never buy those cheap packages.
06-27-2015 06:07 PM
06-27-2015 07:59 PM
If it is the lens, can it be fixed or would I have to throw it away? and is it possible to know what might have caused this so it doesn't happen again?
Unfortunately not, the people I know are Nikon users (so unfortunate haha)
06-27-2015 08:46 PM
Here is a before an after
Before ( with nothing on top of the lens)
After (with a wide angle lens placed on top of the standard lens)
How is it possible that a wide angle lens on top of it is improving the quality??
06-27-2015 08:53 PM
Are you for real?
Take a picture of your exact set-up with your phone and u/l it here. The camera. The lens. The add-on lens or lenses.
I trust you did not do as I suggested?
06-27-2015 09:06 PM
I did do as you suggested, even emailed them just incase the reponse might be different but they instructed me to either send my lens to one of their repair centres or go there myself but the closest one to me is hours away so I won't be able to go all the way there.
06-27-2015 09:52 PM
06-27-2015 10:34 PM
@ebiggs1 wrote:Whatever that piece of junk is on the front of the lens, remove it. It may have damaged your lens. If it did Canon will not warranty the lens.
Is that even an actual Canon lens? And is it a complete lens without the WA attachment? Without the WA attachment the image quality is so bad that I wonder if it's an incomplete lens that accommodates a variety of attachments (WA, telephoto, normal, etc.), one of which must be there at all times. Such lenses did exist long ago, though I've not heard of one recently.
06-29-2015 08:27 AM
It is, that's the thing. When I innitially got it, everything was of great quality without any issues >.< but it must be what ebiggs said, the wide angle lens must've damaged it or something, I don't know
