03-08-2023 11:02 AM
Hello, i've had my EOS 250D for two weeks now. Since today when I click the shutter button the screen goes black and the red "writing to sd card" light goes on, it takes 10 seconds to 10+ minutes for it to reset. Afterwards the photo is not on the SD card. Videos still do work.
Nothing weird happened that could cause this, last week I had the same issue but it fixed itself after an hour or so. It now has already been 5+ hours sadly.
Is there anyone that has experienced this before that knows how to fix this?
03-08-2023 11:20 AM
What specific card are you using? Hopefully it's a full-sized SD card (micro cards with adapters can cause numerous issues).
Peek inside the card slot to see if there's any damage or corrosion to the connectors.
03-08-2023 11:38 AM
SanDisk SDXC Extreme 64GB 170mb/s, i've formatted it and I bought it new for this camera. The connectors seem fine, I have only inserted it 2 weeks ago and never touched it since today. So sadly it's not that 😞
03-08-2023 11:30 AM - edited 03-08-2023 08:12 PM
Have you formatted the SD Card before first use in the camera. If NOT it could cause the problem that you're describing. Also @rs-eos pointed out that using Micro SD Cards in an adapter cause these problems too. In this case use a Full sized SD. Canon cameras DO NOT like Micro SD Cards in an adapter.
03-08-2023 11:42 AM
Yes I have, it was a brand new SD card
03-08-2023 11:54 AM - edited 03-08-2023 08:13 PM
Was the SD Card formatted in the camera also is it a full sized card. What size is it too 8GB, 16GB, 32GB etc.
03-08-2023 12:01 PM
Refer to the OP's earlier reply: "SanDisk SDXC Extreme 64GB"
03-08-2023 12:04 PM - edited 03-08-2023 08:13 PM
That card may be too big for there camera. I know that lower end cameras rebel, XXXXD, XXXD don't like cards larger than 32GB SDHC. Even though the manual states otherwise. I posted my response before OP responded. That's why I asked for the card size.
03-08-2023 12:08 PM
Thanks for the idea, i'll try a 32GB one tomorrow!
03-08-2023 12:06 PM
It was indeed formatted, full size and 64GB
