01-14-2021 07:40 AM - edited 01-14-2021 07:43 AM
My canon 5d Mark iii cannot be recognized by my computer (windows 10). I have the right software, I have a new 200U cable that I bought on Amazon. My camera doesn't have wifi settings to turn off. I have tried everything I can think of to test the usb port. I keep wondering if there is some obscure setting or mode that I have to turn on while I'm trying to use the usb port or maybe do I have to have it plugged into power instead of using a (fully charged) battery?
The camera is in great condition other than this and I'm wondering if there is any other advice anyone has on this issue before I give up...
Thanks in advance for your kind assistance.
01-14-2021 09:40 AM
Would a card reader work?
01-14-2021 10:22 AM
Thanks for the response.
I want to use it for video conferencing.
I also want to be able to sell it when I decide to upgrade to a newer model. If I'm not mistaken, you need to be able to access the 5DM3 via usb to change the owner name which is applied to every photo's metadata.
01-14-2021 10:38 AM
@MikeE wrote:Thanks for the response.
Understood.
The copyright info can be changed via the menu system, but everything else would require repair. eBay frequently has parts like that.
01-14-2021 10:47 AM
If you haven't already, definitely try a different computer and a different USB cable before digging into the camera.
I have experienced more than one USB cord that was defective from delivery and Amazon is definitely not what I would call a reliable source with lots of products that are counterfeit and in other cases repackaged returns that were defective the first time they were sold and still defective. Amazon is a blend of Amazon corporate and independent sellers and it is even more of a "wild west" than ebay which has a much better feedback system that properly matches feedback with seller instead of the Amazon system which often blends feedback/reviews for multiple different products together.
I have run into communications issues with different Windows 10 computers, often related to either security software or some other program running on that system, so also try it on a different computer.
USB ports can be damaged or go bad but I would put the probability of that at lower than that of a defective cable or another of the many issues that follows Win 10 like sharks to fresh blood.
Rodger
01-14-2021 10:20 AM - edited 01-14-2021 10:20 AM
If everything else seems to work properly it could be the USB port.
As kvbarkley says maybe you can just not connect the camera to the computer.
01-14-2021 10:26 AM
I'm an IT guy that has done many computer builds and repairs.
If the USB port is dead, can I replace the PCB myself?
If I can't replace the PCB myself, how much does this kind of repair run (ballpark)?
If I can replace the PCB myself, where is the right place to buy it from?
Thanks All
01-14-2021 12:13 PM
It could also be that the USB port has been pulled from the PCB. You might be able to repair it.
01-14-2021 12:20 PM
Although the PCB can be swapped out, not by me, but a relatively adapt electronics person, you would still not have the equipment to adjust settings and tolerances.
I am another don't buy from Amazon. Go to a known good retailer. Not a flee marketplace like Amazon. Not eBay either! Before you do a drastic repair on a fairly expensive camera, do check out a different computer and USB cable.
01-19-2021 06:02 AM
Although you may be able to buy a new main PCB it would need Canon's service software to set it up, if you buy a used PCB then it would have the set up information on board but it wouldn't necessarily match the adjustments required for your camera body.
