06-23-2014 08:48 PM
All of a sudden my computer won't detect my Rebel XT. I replaced the USB cord but nothing is even detected in "My Computer" or in the Device Manager. I am sure that the USB ports work properly as they work with other devices. I reinstalled the software it came with and tried changing the communication settings on the camera. Does anyone have any suggestions?
08-28-2017 06:15 PM
If Windows 10 does not have the Windows Media Player installed, then you will need to install it. You can download it free of charge from Microsoft. Also, I have heard a rumor that you may need to enable media sharing.
08-29-2017 09:26 AM
... you may be using the "Home" edition of Windows 10. I believe that edition lacks some necessary display utilities that are present by default in the "Pro" version.
Win 10 had an update to their camera recognition utility a few months back. It is installed on both my 8.1 64/Pro and Win 10 Home machines. However, even if Win 10 doesn't recognize the camera, it should recognize that there is some new hardware attached and allow the user to install drivers. That the computer doesn't see new hardware suggests to me that the problem is not with the computer or Windows.
08-29-2017 09:46 AM
Install the software on the computer before connecting the camera.
Using a fully charged battery, set up your camera unattached to the computer. Use the manual that came with the camera. If you don't have a manual, then go to Canon Support and d/l one or read the online PDF. Follow the directions setting the clock, name, etc.
Also, as mentioned above, make sure that the WiFi is turned off. The camera will not connect through the USB if it is set to WiFi.
Good luck
06-10-2018 04:34 PM
I have the PRO EDITION, and my computer card plugged directly into a USB port won't reconize or read my card.
I have done this for years now on this very same computer and with the Windows PRO. It just isn't working and won't read my card.
HELP?
06-10-2018 08:00 PM
@KayHoward wrote:I have the PRO EDITION, and my computer card plugged directly into a USB port won't reconize or read my card.
HELP?
I don't understand what "my computer card plugged directly into a USB port" means. Cards don't plug directly into USB ports; you need a card reader. Are you using a card reader built into the computer? If not, you'd have to connect your card reader using a USB cable. Some USB cables are only for charging cell phones and lack the strands that support data transfer. The computer won't see a camera or card reader connected via such a cable.
06-10-2018 08:18 PM
I meant to say it is my Camera memory card plugged directly into a USB port in my all in one computer. And yes I have a card reader in my computer and I finally tried that and now my photos are downloaded. How it got turned off I have no idea unless some Windows Update turned it off. Grrrr!!!!! I have over 6000 photos in my computer. So when this wouldn't work (for the first time ever), I was baffled.
Thanks for your imput.
KAY
06-12-2018 10:45 AM
You're not using a Micro SD card with an adapter, are you?
09-06-2018 02:41 PM
thank you this totally worked for me and my rebel xt with my Alien laptop.
10-18-2018 05:24 PM - edited 10-18-2018 05:28 PM
I have a Canon 6d that will not read on my Macbook Pro when plugged in through the USB. It used to work a few weeks ago, but now it stopped working. I dont think anything has changed nor have I changed anything. The USB that came with the canon from original purchase has literally only been used once so It cant be the USB cord. I have researched everything and dont know what to do. Need some advice/suggestions/everything.
10-18-2018 05:32 PM
USB cords can be defective from the start, die after one use or a thousand. The USB cord that came with my iPad worked once to charge the iPad, suffered no physcial trauma, but never worked again. With an issue like this try a different port on your computer AND then a different cord. You can also try connecting another USB device to your computer to see if it is recognized by that port.
Rodger
