01-02-2013 07:22 PM
What is the fastest and largest memory compact flash card I can use with the EOS Rebel XTi
01-06-2013 12:29 AM
01-09-2013 11:13 PM
Hi Gfarina,
7D5D is correct in that you really can't go too fast. Faster memory cards should be backward compatible with your camera.
The largest memory card this camera will accept is 64GB.
I hope this helps,
Richard
03-31-2016 12:44 PM
So this card;
SanDisk 64GB Extreme Pro CompactFlash Memory Card (160MB/s)
should work in the Rebel XTi?
03-31-2016 03:59 PM - edited 03-31-2016 04:05 PM
What I found:
If you stick a udma CF card into a non-udma camera like 400d/XTi, then the camera will default back to much slower PIO (programmed input/output) mode 2 or 4. It will still work, you just don't get the blazing speed that your udma card is designed for.
PIO mode 4 is around 16 MB/s.
Canon 350D, the one before 400D, can use 6 MB/s.
03-31-2016 04:17 PM
04-01-2016 07:15 AM
@Peter wrote:What I found:
That makes perfect sense and is fully consistent with what Richard of Canon said three years ago. Backwards compatibility just means that it works, not that you'll necessarily get all the benefits of the newer device.
Frankly, I'm a bit surprised that the XTi will accept a 64GB card, Ten years ago when my wife and I bought our XTi's, 4GB and 8GB cards were the norm. (Actually, I think our cameras came with a 16MB card!) I suspect the original firmware would have choked on a card that large.
04-01-2016 10:28 AM
A SanDisk 64GB Extreme Pro CompactFlash Memory Card is probaly worth more than the camera!
04-01-2016 12:02 PM
The camera works well for my needs!
04-01-2016 12:03 PM
Yes, I had five of them. They are great cameras.
