06-11-2022 01:27 PM
Using the following settings I had my new R5 overheat within 30 minutes of normal use at a wedding.
Also called BH Photo and Video support and they were also able to replicate the problem. Amazing support since this is not their problem!
Firmware version 1.5.2
One test using only CF Express Card
One test using only SD Card
The CF Express card lasted about 15 minutes longer before the overheating situation happened.
Set the camera to video.
1080P (Not using 4K or 8K as those had known isssues)
120FPS
Should have a max record time of 7:29 with these settings. Do a couple long recordings of 7 minutes long with the back LCD running. For me... the max record time dropped to 5,4,3,2 then 1 minute after 2 recordings.
At 2 minutes the overheating symbol starts flashing. After a couople more recordings max record time was 1 minute than flashing 0:00. Camera done.
For me... it happened within 2 full 7 minute recordings. For B&H... they saw the same thing happen after 4 recordings. Now, this was just to test the problem. I normally record 10 to 30 seconds at a time. We just did full 7 minute recordings to replicate the problem faster.
I called Canon Support and they refused to even test the problem on their end as this shouldn't happen. That's really poor support as they said this should not happen. They also had me check the OverHeating option was checked in the menu. With the new firmware 1.5.2 this option is no longer in the menu system! Camera Icon, sub-menu 8.
I was wondering if anyone else could test this with their R5. Possible test it with a different firmware version, and then with the latest version 1.5.2?
PS: Setting the camera back to 60FPS turned off the overheating and I could use the camera.
06-16-2022 05:16 PM
I'm really sorry you're having problems with the R5. That's a big investment to have it not work for you.
There are as many use cases as there are people, and they're all valid. Yours, as you explained it, makes perfect sense; it's just a shame that it doesn't work on the R5.
I personally think it's a fantastic video camera -- having been using it since last July -- but with limitations. If someone had asked me if I would use it for weddings, for example, I would have said no, because of the record time limit. If you're recording an hour-long ceremony, you'll hit that before it overheats, at least at 24 FPS.
I have to say I'm surprised you're getting overheating relatively quickly, at 1080p. But then again, the camera is juggling 35 megapixels and downscaling from 8k to 2k, all at 120 FPS... so thinking about it, maybe not so much. Which doesn't help you, of course.
Between the issues you've identified with the R6, and the overheating on the R5... I hesitate to mention this, because it's another huge cost, but it sounds like the R5C would be ideal for you. I just ran couple of battery tests shooting 4k at 120 FPS; I got 39 minutes and 43 minutes back to back, no overheat, just the fan came on. Battery life isn't great on the R5C, but there's no record time limit, overheating seems like it's solved, and it does "Double slot recording" (i.e. dual slot). You can run it with USB power if you have a 30W PD battery bank and cable. One thing is that the operating system is totally different to the other R cameras, it's more like the C70.
Anyhow, I hope you can get something working.
06-11-2022 06:45 PM
The principle source of heat build up is the memory card slots. Try using an external recorder with an external microphone connected to the recorder.
06-12-2022 02:25 AM
Sorry I don't have much help for you, but a few points:
I'm surprised to see this in 1080p mode. I regularly shoot 30-minute clips in 4k HQ (aka "fine"), no problem. A second clip straight away will overheat. I'm recording to CF in camera. Basically I can shoot 57 minutes continuous (I have to press record after 30 minutes) before overheating shuts it down -- again in 4k HQ. I have no idea why 1080p would be such an issue, since I don't use it, but maybe the downscaling is extra work? Try 4k HQ.
In 4k LQ -- which is really quite nice -- I couldn't make the R5 overheat at all, even after 5 hours straight recording.
So maybe try shooting 4k??? You can always downscale in post. 4k LQ downscaled to 1080p should look great.
The 7:30 time limit when shooting 120FPS is due to the "tax law" record time limit; not overheating or battery. When you shoot 120FPS, the record time is limited to 7:30 because the playback time of the video would be 30 minutes.
The "OverHeating option" in the menus is now called "Standby Low Res".
I am running 1.5.2.
06-12-2022 12:03 PM - edited 06-12-2022 12:04 PM
Thanks for the advice AtticusLake! While that makes no sense that shooting in 4K instead of 1080P... stranger things have happened! 🙂 I'll give it a try.
I already have the Standby Low Res set to on.
Waddizzle:
I appreciate your insight and time to comment on this issue. I do understand what is the main culprete that over-heats. Using an external recorder would solve the problem.
Kinda like if the LCD starts malfuctioning, using an external monitor would solve that problem.
If the shutter button stopped working, using an external trigger would solve that as well.
It's like you bought a new car and the trunk only worked for half an hour. Then were told just don't use the trunk and hook up a trailer. Problem solved! It's kinda unacceptable.
Im not upset with you or your solution as you're trying to help.
I would really like to hear from other Canon R5 users if they are experiencing this issue at 1080P and 120FPS with long recordings. It's happening to me and to the support staff at BH. I imagine it's happening to others. I'd like to find out if it's the firmware or camera or....????
Its crazy to me that I have 2 other Canon R6 cameras with lower specs and performance than the R5 and they run perfectly. I actually upgraded to the R5 for the performance. For right now, I can only use my R5 for wedding ceremonies where I run at 1080P and 60FPS.
Thanks again for any help other photographers can report on this issue.
06-12-2022 12:21 PM - edited 06-12-2022 12:25 PM
AtticusLake,
Would you mind testing the 1080p 120FPS on your camera. You'll have to press record a few times at the 7:29min mark... but see if your record time starts to change after the 2nd, 3rd, 4th recording. and dropping?
I know it's not suppost to happen... but it does.
Im running a test in my office right now using 1080P and 60FPS and doing a couple 30 minute recordings. Then going to switch back to 120FPS and see if it still reads 7:29 as my max time... or the camera comes back with less record time. Just to see if it's "starting" to heat up at those settings.
Appreciate the help!
06-12-2022 12:22 PM
Everyone experiences overheating at 120 fps.
06-12-2022 12:51 PM - edited 06-12-2022 12:57 PM
The question is why is that happening to the R5 and not R6?
Not angry with you... but it's pathetic!
The camera has a major design flaw. I can use my R6 all day at 120FPS without problems and writing to multiple SD cards at the same time.
We all bought a race car and it seems like everyone is accepting the fact that it's a lemon and only good for a couple laps around the track.
Before you say, just return it to BH... I bought it from them but live in Mexico. I'd love to get my money back and buy a 3rd R6! Cost too much money and the people who brought it down threw away the box.
06-12-2022 01:05 PM
I think you'll find that most of the heat is generated in the camera's processor, not the CF card. The card does get hot, like everything, but the camera's CPU is doing a colossal amount of work.
06-12-2022 01:15 PM - edited 06-12-2022 01:16 PM
I would agree with that... but then using an external recorder shouldn't fix the problem.
I haven't tried that yet, but its seems to be the fix with other photographers.
The cost difference between the R5 and R6 is $1400usd. ($2499 and $3899). Huge dissapointment and waste of money for me personally. And I have a camera that looks like it will only be good for photo now. Unless I spend more money to install the "trailer on my new car". 😞
Booooooo Canon!!!!!
PS: Still appreciate your time and help with this.
06-12-2022 01:58 PM
OK, just did the test. I got 4 recordings before it overheated:
total 26:41. The record time limits reported by the cam were 7:29, 7:29, 5:00, and 1:00. Those limits are pretty conservative, though, and I generally ignore them and just let it run.
I guess I'm surprised that I got less total recording than I would in 4k. But not too surprised -- 120FPS is a *lot* of work for the camera. Personally I've never hit this because I wouldn't record for that long at 120. 60 FPS is adequate for all my needs, though I'm usually at 23.976.
As for why the R6 doesn't get this, I guess the R6 isn't doing as much processing. For example it doesn't do 8k, so if it line-skips the sensor down to 4k, then it only has ¼ of the data to deal with. Naturally that's ¼ of the work, and hence ¼ of the heat. And a less good image.
Generally the R5 packs a stupendous amount of processing into a small package with no active cooling. Hence the R5C.
