EOS R6 Mark II tethering problem-- photos don't show up on my computer
AWFOTO
I am desperate. I spent a whole week trouble shooting this, I have been a long term user of Canon and EOS utilities. My husband helped me trouble shoot as well. He works on computer devices, so this is his field. He is also puzzled what is going on. But we are convinced it is a problem from the camera.
Problem:
When I connect my canon R6 M2 with TetherPro cable ( I got both USB-C - USB-C and USB-C to USB-A) , my computer sees the camera, and BOTH with Canon EOS Utility and Adobe LM ( latest version), I can launch tethering and command shutter from the computer. BUT, when I click on the shutter, no photos show up in the designated folder. I am 100% sure my settings are spot on for the softwares. Both EOS Utility and LM have exactly the same behavior. I tried different cables, different USB ports, and 3 different computers ( 6 different USB ports) and various cables, including non - TetherPro ones. Here is what is even more bizarre: Out of the 3 computers, there is one USB-C port that would work ( command shutter click and photos are showing up in the designated folder), and once the camera is plugged to this port that worked, and if I keep the camera on  and plug it to another port that didn't work at prior time, it would work now, I can see the tethered photos in the designated folder. If I then turn off the camera, and connect again to the same USB-C port, the same problem occurrs ( no photo in the designated folder). It was like this one special USB-C port would trigger the camera to work properly and stay that way as long as it stays on. Once it is turned off and back on ( like a re-set), the same behavior occurs-- I can tether control, but no phones are found any where.
What is even crazier is: I also own 2 canon 6D cameras. I can tether with TetherPro cable ( older version for 6D) to these computers with bother EOS utility and LM and exactly the same set- up works perfectly. Photos go into the designated folder. I cannot believe that my old cameras are working fine, and this newer R6M2 does not.
Based on my testing I am convinced that the problem is from the camera. I have the latest firmware on R6M2, I also re-installed the latest firmware just to be sure. There is something wrong with this camera. I bought it directly from Canon.
Has anyone experienced this?  Canon engineer, please help!!!!
#Canon R6 Mark II #tethering problem
9 REPLIES 9
March411
AWFOTO, the Canon moderators maintain the site but do not offer tech support. I believe if one of them stops by they will suggest that you register the camera on the Canon site (if it's not already). Once that is done reach out for support @ 800-652-2666.
The tech support team is a real good group and can assist you in trouble shooting or recommend repair. It may be that the port on the camera has an issue and that is why it works intermittently.
Marc
Windy City
To find common ground you must be willing to search for it.
Our interests intersect more than they diverge.
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
Marc, the support was not helpful. I already tried.
The port is brand new, my camera is brand new with light use. There is no connection issue. When I plug in the cable, I get a crisp definite connection, if you know what I mean. Thank you.
March411
Sorry to hear that tech support was a bust!
Have you attempted to uninstall the current version of EOS utility, download and refresh the application?
EOS / PowerShot / SELPHY Apps & software
Marc
Windy City
Personal Gallery
stevet1
AWFOTO,
Just out of curiosity, and this may be more trouble than it's worth, but have you tried tethering over Wifi?
Here is a video that shows how to do that with EOS Utility, and it looks like person is using an R6 Mark II.
https://m.youtube.com/watch?v=GM6oxDOSXwc
Ps: When you are trying to tether with wired cables, are you sure your Wifi is diabled?
Steve Thomas
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
Marc, yes, I uninstallled and installed EOS utility software many times, I even uninstall my Lightroom, and re-instsall one software at a time. I really tried everything!
Thank you Stevet1,
I thought about Wi-Fi tethering, but I was so discouraged, if wired option does not work, I cannot imagine wireless... no I haven't tried.
Steve, yes, I disabled Wi-Fi, I also tried with Wi-Fi active, same result.
I think there is a connection issue.  That is the basic problem, right?  I am surprised no one has asked about your computer OS and the computer itself.
What OS are you I running?  Are you using a DIY platform, on that you built yourself, instead of an off the shelf computer from a computer manufacturer?
Your comment about only one USB port working got my attention.  The recent comment about the port being new raised my suspicions.  Are you using a passive USB port expander?  They don’t work well with the cameras.  Does the one working port connect directly to your motherboard?
I should point out that the 6D and R6 Mark II use different types of USB ports.  This makes a difference!  Finally, AMD motherboards have a history of issues with their  USB ports.  More recent boards seemed to have cured the problem.
RobinFocus
You may want to confirm Dropbox, Google Drive, etc. are not running.  Those softwares can grab control of the camera, viewing it as a really nice SD Card reader to import photos.  When that happens it can shutout tethering softwares from doing their thing.
AWFOTO
Hello all, thank you for your kind help trouble shooting. I ended up sending the camera to Canon, convinced that there was a defect. It turned out, the circuit board was broken. It was defective. Canon repaired it under warranty. I am thankful it got fixed. Hopefully, this does not happen to anyone else, but if it does, this info can be helpful.
