06-18-2021 07:42 AM
Hello Fellows,
Currently i cant connect my Canon 80D to a Windows 10 64-bit PC over WiFi. i have tried a couple of things so far and i havent gotten successful. im not sure where to go with this, any help or insight would be very much apperiated. here is what i have tried so far :-
06-20-2021 01:33 PM - edited 06-20-2021 01:34 PM
i got it to work on another pc, using another version of the utility software. somehow the version of the EOS Utility out on the US site here was not working, not sure why the camera was not accepting the pairing on it. on the other pc i installed the UK version on my machine it just poped up into the EOS Utility. Uninstalled it on the first pc and it also worked there.
Thank you John & Thank you Wadizzle
06-18-2021 08:49 AM
I don't know if this will help:
Canon Knowledge Base - Using EOS Utility 3.x to Send Images to a Computer (Wi-Fi Function) (EOS 80D)
06-18-2021 01:57 PM
Thank you john,
i went through the link and done everything (till step 3-8) , still i cant get past the pairing. i also checked with EOS Utiltiy 2 & 3 to see if the camera is added before, sadly still unsucessful with connecting both devices. also i started suspecting its a firewall issue and i added both "EOS Utility" and "EOSUPNPSV" similar to what is done in the post (EOS Utility firewall problem)
06-18-2021 04:46 PM
@M_Malhas wrote:Thank you john,
Reset the Wi-Fi, so that it uses the default name for the camera. You probably need to go into the Programs folder and start the "EOS Launcher" manually, just for the first attempt. With many PCs the EOS Launcher will start up when you connect a USB cable, instead of the EOS Utility.
Your camera needs to connect to your LAN, not to your PC. Make sure your the security on your wireless access point is allowing for new onnections, but you should see this from the camera end. It will either connect to your LAN, or it won't.
06-19-2021 11:19 AM - edited 06-19-2021 11:36 AM
hello waddizzle, thank you for taking time off and writing your post.
i have tried the following:
still getting this in the laucher
06-19-2021 11:50 AM
Did you get past the point of router pairing? That seems to be where many folks get hung up. Some routers have a software "button" and others have a physical button.
06-19-2021 12:34 PM
Here is the situation on the camera
06-19-2021 02:16 PM
The camera cannot do the pairing all by itself. It seems like it is not connecting to your WAP. Check your security setup in the router. This would require the router software, not the Canon. EOS Utility.
06-19-2021 02:19 PM
@M_Malhas wrote:Here is the situation on the camera
You need to get past this step. You must connect the camera with the Wireless Access Point, WAP, for your LAN.
06-19-2021 02:58 PM - edited 06-19-2021 02:59 PM
it is connected to the Network, the PC im trying to pair with can even see it in the network. also the camera is on the router's tables.
