EOS Utility crashes Windows firewall
ShadowHowler
Hello.
I bought a 70D a few days ago and wanted to try the wi-fi function today.
I downloaded and installed the latest software for my camera from the Canon support site.
Im having the following problem with the software.
When i run EOS Utility I get the following message:
-To connect to the camera via LAN, some Windows Firewall settings must be changed. Do you want to make these changes?
I click yes and get the next message:
-WFT FirewallSettings has stopped working.
The next message i get after i click on close program says:
Could not change the Windows Firewall settings.
I tried adding the EOS utility and EOS utility 2 manualy, and allowed acces, but it still doesnt work.
Hey,
Follow these steps please :
> In the search bar of the Windows Taskbar type : Firewall
> Click on "Allow an app through Windows Firewall"
> Click on "Change settings" button
> Click on "Allow another app..." button
> Click on "Browse..." button
> Browse to this path : C:\Program Files (x86)\Canon\EOS Utility\ and choose "EOSUPNPSV.exe" file
> Check both "Private" and "Public" for the "Canon EOS UPNP Detector"
> Click on "Ok"
Best
Lynx
12 REPLIES 12
ebiggs1
Not enough info but I will guess it is your firewall and not EOSU.  You need to look there.
EOS 1DX and many lenses.
I cant give you more info than this picture:
I think i found the solution for my problem. I just chenged the language from Slovene to English and it started working.
After that i changed it back to Slovene and it's still working. I hope the program wont give up on me any time soon.
Really .. really thanx a lot .. Czech language works too .. I had the same problem ...
Hi, I have got the same proble with Utility 3.
I try to pair it with my EOS M10 in windows 10 but it always come up with error :''WFT Firewall Settings has stopped working'', May i know how you did with the language settings ? did you mean the OS language setting ?
thanks so much
Did you get any solution to this problem?
Im trying too and get the same error and do not find any solution to it.
Can you help me?
/Stefan
Hey,
> Click on "Ok"
Best
Lynx
It worked! Thank's
thank u so much it working ♥
