Canon 5D Mark IV - ViewFinder Bottom Bar not displaying
Zbizafar
My 5D MK 4 is not showing the bottom bar in the viewfinder (The green one). I checked everywhere but couldn't find the solution to fix it.
Anyone else had this same problem? Do you know how it can be fixed?
Thanks
9 REPLIES 9
Waddizzle
I am not aware of any settings that would disable it entirely.  Try resetting the camera back to factory defaults.  Switch the camera to Green [A] mode to see if the display has returned.  If not, then I recommend contacting Canon Support.
deebatman316
What mode is the camera mode dial in. In full Auto (A+ Mode) the light meter an other things are not visible in the bottom of the viewfinder display.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Thank you for you reply.
its in full manual mode. I have the latest 1.3.3 firmware and I tried resetting the camera as well.
But nothing seems to work
Waddizzle
I initially thought that you had meant that the entire bottom row was not visible.  When in Auto mode the exposure meter does go away.  But, exposure metering should be visible in M mode.
One explanation would be if your top dial were going bad.  When the top dial is set to A or M, what shooting mode indication do you see when you press [Q], Quick Menu?
deebatman316
Try pressing the ISO/ Exposure Compensation button while looking through the viewfinder. Depending on the mode the light meter/ exposure compensation meter should be displayed at the bottom of the viewfinder.
-Demetrius
wq9nsc
Do you have a right or left facing arrow at either end where the bar should be?  That indicates over or under exposure beyond what the three stop scale can display.
Rodger
No. I can only see in the viewfinder the option that you can open from the menu like Auto focus, flicker etc.
The bar below it is completely gone. Looks like a hardware issue to me as I even went to the Canon shop and he didn't know about it. He was of course not a technician but if it was a setting issue should have known about it.
Done that.. pressed all buttons there are 😄 nothing happens.
OK, thank you for clarifying!  I thought you meant just the indicator bar under exposure level was missing.  With the entire bottom bar missing, I am confident that is a hardware and not a setting issue.
Rodger
