08-28-2020 12:10 PM
I recently got a Canon 5D Mark 1 (Classic) and I am using the Canon EF 28:135 Lens that came with my Canon 40D. Using this lens I am getting black corners on all of my photos that I shoot. My Canon 50mm lens works perfectly as well as my EF 70:200 lens.
What's going on here? It is not an EF-S lens and it works perfectly on my 40D but not 5D.
08-28-2020 12:37 PM
08-28-2020 01:13 PM
Thanks for the reply, I will post some pics when I can. I do have a UV/protector on it as well as a Polorizing filter on it. The lens hood is a collapsible rubber hood and it was collapsed when taking the photos.
08-28-2020 12:40 PM
When you say black corners, are they truly black or just greatly reduced in brightness compared to the rest of the frame? This lens does have significant vignetting which is far more obvious on a full frame body.
Is there a non-standard lens hood on it?
Rodger
08-28-2020 01:15 PM
Thanks for the reply, the corners in my opinion are truly black but do soften some as you get closer to the center of the image. The lens hood is a collapsible rubber one that was collapsed when I took the photos.
08-28-2020 01:25 PM
@JasonR wrote:Thanks for the reply, the corners in my opinion are truly black but do soften some as you get closer to the center of the image. The lens hood is a collapsible rubber one that was collapsed when I took the photos.
That lens hood is probably the problem. As advised, stop using it.
08-28-2020 03:20 PM
Also stop the double filtering. If you're using a polarizer, you don't need a UV filter.
08-28-2020 03:27 PM - edited 08-28-2020 03:29 PM
@Waddizzle, are you suggesting there is something wrong with the lens?
08-28-2020 05:47 PM
@JasonR wrote:@Waddizzle, are you suggesting there is something wrong with the lens?
"That lens hood is probably the problem. As advised, stop using it."
Negative. I am pointing the blame at the lens hood.
08-28-2020 01:19 PM
