Can't set multi-function button to use selective focus on 1dx Mark III
geneh
Tried going into the AF4 menu to set the M-Fn button for AF area.  Won't accept it, and still stuck with the dial.  Suggestions?
6 REPLIES 6
Moderator
Moderator
Hi, geneh!
So that the Community can help you better, we need to know exactly which Canon camera model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
1dx Mark III
jrhoffman75
Did you press "Set" after you dialed down to the option?
Yes, no luck,
Mark35mmF2
Hi there,
On this camera you would typically have to press the AF Area button first (the button on the back of the camera, top right corner) and then the M.fn button would cycle through the options. Is that not happening with your camera? I'm referencing the info on page 326 down below for this.
https://cam.start.canon/en/C001/manual/eos1dx-mk3-ug.pdf
If I am understanding the OP's problem correctly he is saying that in this menus option he can't change from dial to M.Fn button.
