10-16-2020 04:25 PM
I had just recently had my 5D serviced/cleaned and firmware through Canon.
Prior to sending it in, I had the AutoFocus mode selector button (the button on the back with the 5 dots in a plus shape in a box) programmed in a way that you can press it directly to cycle through the autofocus modes without having to use the multifunction button. I cannot find how I did that. Can anyone provide instruction on that?
I googled, youtubed looked through the manual but am missing it.
Thanks all.
10-17-2020 11:30 AM
@coop_jeff wrote:Hello John - That is not the one...You could repeatedly press the AF selection button without hitting any other button. I am still digging - it is a quest
What about the top of page 144. I do not see anything like what you describe, at all.
10-16-2020 06:06 PM
You are looking for AF area selection method, I don't have a 5D4 but it is probably the 4th tab under the AF section of the menu. Press menu, scroll to AF and then look at tab 4.
Rodger
10-16-2020 07:45 PM
Thanks Roder - I went all through that and cannot find it. I seem to recall I was watching an on line tutorial or "how to set up" video. I seem to recall that it was pretty obscure.
Obviously not a super urgent matter because I can use the slanted button or multi function, but it is funny, I did use that functionality.
10-16-2020 07:58 PM
Make sure you aren't in the "green" full auto position of the mode dial, you have to be in one of the other modes to have full access to the menus.
Rodger
10-16-2020 08:03 PM
Rodger - Thanks, I am in full manual mode. I will play around with some of the semi modes. and see if that makes a difference.
10-16-2020 08:38 PM
Is top of page 504 of manual what you are looking for?
10-16-2020 09:11 PM
10-17-2020 11:30 AM
