Canon RF 100-400 Autofocus problem
Len29
Hello,
Does anybody have an issue with autofocusing in 400mm with this lens? When I extend the lens to 400mm and try to focus, the lens is not focusing. I have to retract the lens to 100mm and refocus. Only then autofocus works. It happens almost every time in any mode(M,Av,Tv or Fv). Camera Canon R6.
15 REPLIES 15
@rs-eos wrote:
You shouldn't have to enable that setting to force the lens to focus.
This is sounding like you have an issue with the camera.  I would first reset all settings and try things out again.   If the issue remains, you probably should look at sending it in for a repair.
That is exactly what the problem is. Long telephoto lens can get grossly out of focus so the camera can't "see" anything to start focusing on. I had the exact same problem with my 1D X MkIII. I had utilized some recommended settings from an online user. Lens wouldn't focus when I was trying to focus on ospreys flying.  If I manually focused to get the birds close then it focused OK.
If I switched out of the custom settings back to my basic it worked fine.  Took a while to sort out the problem.
Thank you for this added explanation, John!  I had assumed incorrectly about the default value of that setting as well.
Ricky
wgeoghegan
I had no idea that happened while I was taking pictures. Lost lots of shots. I thought  the lens was bad.
There are so many choices on the R6 that just understanding what each one means is a struggle. I wish the manual were set up differently so for example if one looked up autofocus everything would be on one or a few pages. As it is currently 19 different pages come up on a search of the manual for autofocus.
So, yes I was using the RF 100-400 lens with my R6 and my shots were blurred at 400 mm. My shots at 100 mm were fine.
You know this thread is almost 3 years old? Probably no one around any longer.
EOS 1DX and many lenses.
rgl47
Answer to your first question is yes. Response to your statement is no, I didn't know no one was around any longer. I was trying to reach or elicit information directly from Ricky, aka rs-eos. Thank you.
