‎02-27-2023 04:01 PM
Hello,
Does anybody have an issue with autofocusing in 400mm with this lens? When I extend the lens to 400mm and try to focus, the lens is not focusing. I have to retract the lens to 100mm and refocus. Only then autofocus works. It happens almost every time in any mode(M,Av,Tv or Fv). Camera Canon R6.
‎02-27-2023 07:19 PM - edited ‎02-27-2023 07:49 PM
I just reset the camera setting and the default is "on" for this setting.
from the canon r6 manual below instructions need to be expended:
‎02-27-2023 04:26 PM
I don't own this lens, but just a couple questions to help troubleshoot:
‎02-27-2023 04:37 PM - edited ‎02-27-2023 04:38 PM
This is my second RF100-400 IS USM lens. Both behave the same, whether IS is ON or OFF. The autofocus is not working when I extend the lens to 400mm and it's out of focus no matter which button I use(back buttons or main release button). I tried to gradually zoom out while holding AF button and sometimes it start focusing at around 135mm. But most of the time I have to retract the lens to 100mm in order for lens to start autofocusing.
‎02-27-2023 04:48 PM
If you have other RF Mount lenses do they work correctly on this camera.
-Demetrius
Current Gear: EOS 5D Mark IV, EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 50 F/1.8 STM, EF 85mm F/1.8 USM, EF 70-200mm F/2.8L IS III USM, 470EX-AI & 600EX II-RT
Retired Gear: EOS 40D & Sigma 17-50mm F/2.8 EX DC OS HSM
‎02-27-2023 04:57 PM
Update: The "problem" is solved. In the menu; AF; #4; "Lens drive when AF impossible" was OFF. When I changed it to ON, AF is working without any problem.
‎02-27-2023 06:24 PM
You shouldn't have to enable that setting to force the lens to focus.
This is sounding like you have an issue with the camera. I would first reset all settings and try things out again. If the issue remains, you probably should look at sending it in for a repair.
‎02-27-2023 07:03 PM
Thanks, You may be right. My other RF24-105 L f/4 lens is not doing this. But it's not 100-400mm zoom. I'm going to call Canon tech support tomorrow about this, will see what they say.
‎02-27-2023 07:11 PM
@Len29,
I think the default is "on" for this setting. I'd have to verify.
Canon : Product Manual : EOS R6 : Customizing AF Functions (start.canon)
‎02-28-2023 04:21 PM - edited ‎02-28-2023 04:23 PM
I called Canon tech support today regarding my issue. Their response was: Your lens and camera work within the normal operation. And they suggest using "Lens drive when AF impossible" and "Continue focus search: ON.
