01-15-2026
04:36 PM
09:19 AM
Hello 🙂
i have canon 300v but i would like to buy a canon 3000n and 1000F n for quite low price but i need some advice if they are good as similar the 300v that i have in 3 units or not ?
are in good conditions very low price.
But is there any know defect ?
with central point is fast the autofocus with modern lens as the 300v ?
inside the view finder is possible to have numbers that show exposure ?
01-15-2026 08:59 PM
AF is only as fast as the lens mounted to the camera. Most of the time the center AF point is the most sensitive AF point available. The EOS 1000F was released in the early 90s and the EOS 3000N was released in 2002 and has more AF points available. It is also a more powerful camera and can use the modern E-TTL flash system which is compatible with all EX series speedlites. The older EOS 1000F can only utilize A-TTL or older off the film TTL flash which is only compatible with older EZ series speedlites with a flash sync of 1/90th sec and HSS (High Speed Sync) is NOT available it predates its creation. But the EOS 3000N supports HSS.
