01-15-2026
05:55 AM
08:37 AM
hello guys ,
so I own two R6 cameras one the original canon R6 mark 1 and I recently got the canon R6 mark 3. I never had any issue with mark 1 but I started using R6 mark 3 today and I found wobbling issue. Please let me know if anyone is facing such issue.
01-15-2026 06:32 AM
Welcome to the community. Sorry to hear that you are having issues. We will need a lot more information to help you.
What is “wobble”? Can you explain how we could reproduce this issue? Start with what lens you are using and camera settings.
The term wobble suggests that you are capturing video. If you are using a tripod to capture video, then you should disable image stabilization, especially when you are panning.
01-15-2026 06:35 AM
So right now I’m using r5 35 mm lens . Wobble as in video shakes in between a lot.. I’ve taken video on my phone of shake but I can’t share it here as there’s no option ..
01-15-2026 06:48 AM
Posting a video of the issue could be useful. What would be more useful is to describe what you are doing. What are your camera settings? How to reproduce the issue? Are you using a tripod? Etc.
01-15-2026 06:54 AM
https://drive.google.com/drive/folders/1L8IB4XPUi6OkGrL6qVK9HtEVIUmXX7H6
so I’m sharing drive link so you’ll understand what kind of shake I’m talking about . Also I was using handheld camera and didn’t use tripod
also I had normal setting for video
01-15-2026 08:00 AM
https://youtu.be/x_9QmhB76DE?si=oD_YlHoWRcmFkNDF
01-15-2026 11:08 AM
That Video has way lesser shake and its on the outer side. My shake comes in the middle and it literally wobbles Shaking Video
01-15-2026 11:34 AM
You've mentioned four different cameras.
So you're using the R6 Mk III and which lens?
You're shooting handheld. "Jelloing" from ibis usually appears in the corners when using a wide-angle lens. Wobble in the middle of the frame is not common.
01-15-2026 11:36 AM
Hello
Im using r6 mark 3 and rf 35mm 1.8 lens also i've shared the video which shows the shake/wobble in middle
01-15-2026 11:37 AM
Give Canon support a call at 1-800-OK-CANON.
