10-06-2021 09:28 PM - edited 10-11-2021 09:52 AM
Sorry folks I did not phrase my question right regarding the issue with my scanner - My question is how can I make my scanner scan the document to a PDF file. When I scan using the scanner it scans to a TIF/JPG format by default - I dont see any option to switch it to a PDF file and I cant convert a JPG file to a PDF file.Please help if you can. Thanks - My printer is cannon G4210 - I Initiate the scan from my PC. I have DELL XPS PC with Windows 10.
10-27-2021 04:10 PM
Hi naushi,
Please go to the Canon Utilities folder on your computer and select IJ Scan Utility. Once IJ Scan Utility is open, select the document option. This will allow you to scan and save documents as a PDF.
10-27-2021 10:02 PM
10-27-2021 04:10 PM
Hi naushi,
10-27-2021 09:18 PM
I am unable to find canon utilities on my c drive - I checked under program files (x86) - I guess I need to install it
10-27-2021 10:02 PM
I installed th utility and it worked - Thank you
11-19-2024 11:32 AM
Hello I am new here. I have a real issue, for some reason my scans do not work and also it sometimes scans to Word instead of PDF. I do not know how to find this "Canon Utlity folder or IJ Scan Utility." anywhere.
I have a Canon Image Class MF455dw and I use Windows 10. Where do you find anything to do with the Canon printer, for the scanner????
Thanks for any help you can provide.
11-19-2024 11:34 AM
On the other note, so many times when I scan especially several pages, it gives an error that it did not
scan, however, no reason is given, nor explanation.
