PIXMA G4210 How to scan to a PDF file instead of TIF/JPG
naushi
Sorry folks I did not phrase my question right regarding the issue with my scanner - My question is how can I make my scanner scan the document to a PDF file. When I scan using the scanner it scans to a TIF/JPG format by default - I dont see any option to switch it to a PDF file and I cant convert a JPG file to a PDF file.Please help if you can. Thanks - My printer is cannon G4210 - I Initiate the scan from my PC. I have  DELL XPS PC with Windows 10.
2 ACCEPTED SOLUTIONS
ArthurJ
Hi naushi,
Please go to the Canon Utilities folder on your computer and select IJ Scan Utility. Once IJ Scan Utility is open, select the document option. This will allow you to scan and save documents as a PDF.
I installed th utility and it worked - Thank you
3 REPLIES 3
ArthurJ
Hi naushi,
I am unable to find canon utilities on my c drive - I checked under program files (x86) - I guess I need to install it
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
