pixma ts3500 series printer offline
jmvsmv
I am trying to hook my ts3500 printer up to my home network wirelessly, and connect it with my laptop. I recently switched providers and trying to go from the old router to the new. I downloaded and installed all the software, going through the canon website. I got the printer to find the signal, shoes the wireless icon, the phone icon, and the signal bars on the printer. I got all the way through the setup to where it says to print a test page, and when i hit the button it prints a test page. However when i try to actually print a paper off of my laptop i get the error message that the printer is offline. I have restarted my laptop, and the printer, but still get the same message. What would cause it to recognize the printer and print a test page, but not recognize the printer when i am trying to print my own document? Has anyone else run into this before? Am i missing something simple or is there a larger problem?
Thank you in advance for any help.
5 REPLIES 5
What OS (version and build) are you using the printer with?
What drivers did you use for the install?
Since the printer had been working before, did you remove it prior to attempting to update the printer's connection to the new device?
Router:
What's the IP assigned to the printer?
What's the IP assigned to the computer?
If you open a web browser and enter the printers IP, does its webserver display?
thank you for responding. here is what i have
windows 11 home
version 22H2
build 22621.819
no i didnt remove the printer before updating
printer address is 192.168.0.163
computer address is 192.168.12.1
and no i dont get a webserver display
Here is the issue:
The devices that are trying to communicate are to communicate are on different LAN segments.
Just a guess. Is the computer you are using connected to VPN at a workplace?
If not, then you need to determine why devices connected to the same network are being assigned different IP addresses?
Thank you for responding again. This set up is at home on my laptop, no VPN. My new provider is T-Mobile home internet, which is 5g cellular service, would that have anything to do with it?
The printer has a 2.4Ghz radio. It can only connect to a 2.4Ghz wireless broadcast. Is the T-Mo equipment dual band? 2.4/5G. I doubt its only 5G but its certainly possible. If you provide the model I can probably tell you.
Try logging into its interface and seeing what bands its supports, and how its wi-fi is configured, etc. Dual or tri-band devices that use the same SSID name for all broadcasts (bands) can sometimes confuse single band devices (your printer) during initial connection. Sometimes temporarily disabling the 5G broadcast can allow the 2.4Ghz device to associate and connect successfully. You can then turn 5G back on. I have a tri-band device and have given each broadcast its own name. (Just providing this as an example)
