Desktop Inkjet Printers
MX432 prints erratic and incomplete pages
** I have tried both wireless AND wired connections.  Each act the same**  It will usually print the first page or copy fine, however the second page or copy is ALWAYS cut off.  I have cleaned and aligned that print heads to no avail.  I am not print...
Using up small black ink tanks
Is there a trick for using up the small black ink tanks used in my iP7220? I'm always stuck with several cartridges of that ink, yet the large ones seem to wear out at the same rate as the three colours. Very mysterious! Thanks.
GinaB by Contributor
  • 4180 Views
PIXMA TS 6051 - Cannot print double-sides / duplex
Hello, OS X Yosemite - Canon drivers: mac-ts6000-1_1-mcd Printing from Application Software (Mac OS Printer Driver)http://ugp01.c-ij.com/ij/webmanual/PrinterDriver/M/TS6000%20series/1.0/EN/PPG/dg-print01_03.html ____Although the two-sides box is chec...
pippipoo by Apprentice
  • 4382 Views
Persistant horizonal lines
I am using an ix4000 in Windows 10.  Mostly in Photoshop CC.My prints have developed unwanted regular horizontal lines across them at intervals of about 10mm. I have tried the various maintenance tools available on the software, without any improveme...
Snark by Apprentice
  • 3441 Views
canon mx920 printer
Whenever I try to copy an item, a letter that I long ago copied shows up instead.  I have checked the memory and it shows nothing .  How can I clear this from my printer
Canon Pixma MX922 Save as PDF
I am able to save a document as a PDF using the Print option. However, I have a word document that has 36  pages. It saves the first 30 to one document and the remaining pages as separate documents. This happens with documents as short as 6 pages as ...
oevy by Apprentice
  • 2936 Views
  • 0 replies
Ink refill
Hi, I'very done numerous DIY Ink cartridges refill in Kit form but, just recently I refilled both Cartridges on my Canon MG3250 Printer, but it's now flashing empty Black Ink any suggestions please ?
froyb by Apprentice
  • 4018 Views
  • 0 replies
MG 2922
I bought that printer yesterday and I did set up as on the instruction paper.After that, I did test print and the dialogue box showed SUPPORT CODE 6000. On the printer, green and orange lights were flashing alternately 3 times. I searched about alter...
Detecting printer
Hi My Canon MG3250 won't print due to the printer not responding. The message says " Error printing on Canon Series MG3200 printer ". Troubleshooting tells me that the printer cannot be contacted over the network. The printer was working when I bough...
AlG1 by Apprentice
  • 4787 Views
  • 3 replies
How to scan a document to an email to send
Please provide instructions on how to scan a 3 page document to an email for sending. I use Outlook 2013. I have an HP PC with Windows operating system. Thank you. I have a Cannon MG5420, Windows 10, and use my cable company cox.net.
Selphy cp1200 driver won't install on windows 10
Hi, I've tried installing the printer driver v1.1 as I have windows 10. When I try to detect the printer wirelessly no printer is shown under the "Automatic detection of the network printers" step so I cannot complete the installation.A previous thre...
