Desktop Inkjet Printers
Canon Pixma MG3600, in Control Panel?
I go into Control Panel and the MG3600 is there, but greyed out.I used to be able to right click on the Icon and select scan etc, but couldn't now for some unknown reason?I've checked the lead inputs etc.And I DID download the driver from the CD.Any ...
bobmax by Contributor
  • 2896 Views
scanner not working
I have a Pixma MG6220 and I can't scan documents to my computer. I was able to do it earlier but now I don't have "use scanner" icon in my main menu and quick menu. Do I have to install some extra driver or what I can do? Because I lost my CD I insta...
Ibg by Apprentice
  • 348243 Views
  • 62 replies
  • 4 likes
TS8050 Multipack Cartridges - Gray?
In preparing to buy a set of replacement cartridges, I noticed the current multi-pack offering from Canon (and stores here in Paris) don't include the gray GY571 cardtridge, but a black cartridge instead. The slots on my printer are labelled from lef...
Calsal by Contributor
  • 1740 Views
  • 0 replies
B200 fix
To fix the B200 error, do the following:1. Unplug power cord.2. Lift printer door for cartridge.3. Plug power cord, then press power button.4. Watch the printer cartridge to start moving.5. When you see the printer cartridge moving from right to left...
B200 canon error
Canon MG3600 question?
Hi.Just purchased the MG3600, and I find it has a problem printing in my usual Pale-Moon (derivative of FireFox) browser.Prints in edge though.Is this normal?Thanks Bob
  • 2111 Views
False paper jam message
Hi,My MX726 printer has been working fine, until I went to print today when it indicated there was a paper jam. The Support Code  is 1313, and the display said to remove the paper from the paper output slot and the transport unit on the rear side. I ...
Chapo by Apprentice
  • 2468 Views
How to Adjust the print border on MX922
I have two printers, A Kodak and A Canon. The MX922 print border cuts off my work on all sides and will not print borderless. Is there a way to adjust the print area to prevent the cut off that does not occur with the Kodak or HP printers I have acce...
Canon MX860 printer problems
Printer is suddenly printing all photos in orange hues.  We have cleaned the cartridges, put in new ones and it continues to happen.  Any suggestions other than buying a new printer.
Belasco by Apprentice
  • 8230 Views
  • 3 replies
Resolved! MX512
Hello. When I print document using color print the picture doesn’t look clear, it looks blurred, as though it printed the same line twice with 1 mm apart. But black and white picture prints fine.
Printer spits out blank paper
My printer started to print out blank paper. The black ink was low, so I changed it with a new Canon ink. It still spit out blank paper. I then changed all of the inks with original Canon ink and it still spits out blank paper. The computer shows tha...
SUZANNEA by Apprentice
  • 5930 Views
  • 4 replies
PIXMA iP8500 good print followed by error message
HI there, Following my earlier post I reluctantly bought a new printhead from China. It arrived swiftly and worked perfectly as soon as installed. However, after a perfect single test print to check the colours, the print on the second try faded away...
TREV1 by Apprentice
  • 2581 Views
