Canon Pixma MX340 stuck in grayscale
Printer stuck in grayscale even though color & black are checked. Grayscale is not checked in print settings.
Canon Forum, I recently upgraded the firmware on our Canon Pixma 922 to version 3.041. This was performed using the firmware upgrade feature within the printer. I'm trying to find a Canon Printer support page that shows the latest released firmware, ...
How do I set the ink dry time using my windows 10 pc? I tried using LAN and direct connection. I go from start > settings > devices > printer and scanners > to TS9100 printer > to preferences OR properties > maintenance > I select any setting (i.e. p...
My scanner has stopped working. It appeared to scan but instead of the file appearing there was a notice " an internal error has occured - take the following measures".check scanner status, restart printer, restart computer, re-install scanner driver...
I have my PIXMA TR8520 printer set up wirelessly. However, when I try to print from my laptop (in a different room from the printer), the FAX screen keeps coming up. Can you tell me how to disable the FAX printing screen? The printer will only pri...
The specifications for the scanner on the Canon MG5420 say that it has a maximum optical resolution of 2400 x 4800 dpi. However, when I adjust the scan settings using the options in the on-device screen, the highest resolution it lets me choose for s...
I am at a loss of what to do about my printer. It prints just fine but I need to photocopy a large document and it makes it copies faint with thick horizontal lines of lighter and darker ink across the page. I have replaced all ink except regular bla...
Hi Folks, Just passing on this info: My MP640 (old I know) stopped working recently after one of those lovely Win10 'updates'. So I will not bore you with the 3 days of uninstalling/reinstalling drivers & software other than to tell you that the inst...
Hello, I am having problem on printing with my Pixma G1411. There is this vertical line on every print. I believe this happened after a paper jam. Both color and b&w have this one line. Place of the line is different on b&w and color print. So I'm gu...
PIXMA mg6220 run dll error message on boot up. c:\users\...\cnmss
When I navigate to the garden I don't see anyway to print 2 pictures on one 4x6 piece of paper. Am I missing how and where this can be done or is it not possible? Thank you
12/27/2019 UPDATE NOTE: Doing a clean reinstall of Windows 10 today fixed the problem, so the following discussion is now moot. My thanks to everyone who tried to help me! I tried scanning something yesterday and got this error message (I don't know ...
I want to set the default paper source to cassette on a TS8120. I'm able to set the paper source at print time for a specific print job, but I'd prefer not to have to set it each time I print a file. This printer offers only two paper source options:...
Hi, I have a canon MP480. I want to print out some photos the exact size I have them set up in Adobe Bridge (4x6 by 6.7). I can't seem to do that using the photo software that came with my printer (Easty-Photoprint EX). It asks for paper size. If I...
HI folks, I've got an MG5220 that is giving me some banding in my printed photos about two inches down from the top. When I print the Pattern Check page I the bottom two cyan block are split in half, with the bottom half lighter than the top half (li...
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
