PIXMA MX922 How to print photos on 8½" x 11" paper only
how can i stop printer from printing photos on small pieces of paper and print on 81/2x11 paper only
Paper is getting stuck on foam under ink cartridges. it will not stay put! Is this piece essential? Will stray ink flow if is removed?
I have a pixma mx922 printer and want to know how to print in black ink only with my iMac. I print a lot of coupons and would like to set the printer to this option especially for this purpose
Hello, I'm having some troubles with my printer Canon pixma MX 715. I had bought it around 3 years ago, it was working fine until I left the unit alone in disuse for approx 4 months. When I went to use it again, ofcourse my nozzles were clogged and...
I unfortunately didn't realize that this printer only uses the number 240 cartridge for ink. However, I bought and opened an 261 ink cartridge is there anything I can do? I know Walmart won't take back the ink.
Greetings. I have already called Canon support about this and received no help whatsoever, so I'm checking with people here to see if they've had the same problem. I've had the Selphy CP1200 for less than two years, and have only used it about 6 tim...
I'm looking to print a design in white on some heat transfer paper. But I'm looking everywhere online and I can't find anything about printing in white. I've tried using the "Color" setting and it doesn't print white. Is there some specific white ink...
Canon MX470 printer won't scan. Code 14,230,1 error message.
I'm wondering if the Canon mx470 can print cardstock? will it work or will it paper jam and etc? the cardstock I have is this <Link Removed>
On setting up my printer for the first time, I came across the step where I enter te wifi password. I mis-entered the password, and I have not been able to get back to that step. When I try to do the wireless LAN setup, it says connected to the netwo...
I recently had to unplug my printer and the date/time showing on the FAX screen (and all of my FAX reports) reset to "01/01 00:00". I believe the date and time were correct after I initially set up the printer. Shouldn't it automatically set the time...
My MX860 is going through color cartridges like crazy, even though I almost never print color. I replaced magenta about two months ago, and printed maybe 5 pages that had any color at all. Not photos, either. Anyone else seeing this? Any suggestions?
Hi! Help! I cannot get the touchscreen to work on my Canon MG6320 printer. I looked it up and I downloaded all the updates, but the firmware has an issue and gives an error that the creater has to update the update?? Turining it off for 30 seconds do...
I just reinstalled for the third time the Canon IJ Scan Utility LIte for my G7020 printer. The printer works find and has always worked fine. I can scan using only the System Preferences Scan function but cannot get the actual Canon Scan Utility app ...
I have a Canon MX870 printer/scanner. My computer uses Windows 7 Ultimate. 64-bit Operating System. I do wireless printing and scanning. Until recently, everything worked fine when scanning on the platen using the "scan" and "color" buttons on th...
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
