Desktop Inkjet Printers
Canon Ts5160 how to close bottom tray
If  your bottom tray doesn’t close all the way in pull the whole tray out and you need to shorten it and by doing it you need to look at your tray and slightly on the left there is a black arrow (pointing at you) with a blue border around it, hold tr...
PIXMA G7020 Vertical Lines on Scans only with the ADF
I purchased my G7020 in April, and it has worked fine up until now. However, the scans using the ADF have begun to have two separate vertical lines running down the scanned image. This does not occur when I use the scan glass.I have followed the proc...
BR549 by Apprentice
  • 2836 Views
  • 2 replies
  • 1 likes
PIXMA G620 Printer problem with ink feed
Printing pink instead of blue when blue text selected.Cartridge showing a quarter used. Enough inks. Nozzle check shows Black, Magenta and yellow but no colour shown for Cyanamid. Printed text - .Black and Red print ok, blue text colour is pinkI have...
ericphit by Apprentice
  • 2313 Views
  • 1 likes
False Sustainability
I read a LOT before I picked a printer and clearly it wasn't enough.   There are refill kits available and we SHOULD be able to use these in these monstrously horrid overpriced single use plastic containers.  I am so completely dissatisfied with this...
