Hi All, My MX492 prints fine with my (new to me) MacBook air 2024. Installed the updated drivers for the printer and scanner--to no avail. Spoke to Mac Sr Advisor at length -- still the computer does not find the scanner. Any suggestions? This is ver...
I've cleaned manually and did deep cleaning. The pattern check works fine, but when printing onto glossy photo paper, the black ink smears badly. Any help?
I have a MG2522 printer that runs out of ink way before its stated page count. I'm primarily printing black and white documents that are a majority of text. It seems to be an issue with this printer. Is there any settings or work arounds to have it w...
Printer isn't printing. I filled black ink, so not an ink issue. I sent doc to print, paper goes through and sounds like it's printing, but the sheet is blank. Color is working fine and no errors showing either. Please help.
What to do when Support code B203 shows up. Tried to power reset and not working.
My MG5520 prints double characters almost completely overlapping and double vertical lines in the nozzle check pattern. Tride aligning the head. That didn't work. Most of the alignment test patterns look like gratings.
I'm using a Canon TS9520 and I have a document stuck in the print queue (status says "deleting-paused-printed"). I've tried canceling it, I've tried pausing it, I've tried printing it, I've tried restarting it. I've switched printer and computer off ...
My canon mx472 won't copy from adf. a message saying place paper on the platen glass keeps coming up. It's always worked in the past. It is detecting the paper. i can hear it beep when i put the paper in the adf. I downloaded and installed the lates...
Have an older Pixma MX320 which has suddenly decided to not feed paper. There isn't any paper jam (I've checked). On top of this problem, it won't let me scan individual sheets even using the platen (glass). Fortunately, I can still copy (both b&w...
My PIXMA TS9020 (2018) is giving me an error message "Ink absorber is almost full". Can I buy replacement parts and replace it? I dearly love this printer. How much longer do I have with it?
Hi all, First time here, I have just bought and installed a Canon Pixma TS5150. Not my first printer, more like about my sixth printer, and my third Canon printer/copier/scanner. I am puzzled as to why its got two paper trays? Never had this before. ...
My New Pixma G3470 maintainance cartridge got filled up in a week without notification How can this be avoided?
I have a ts340 and it says it needs pg 445 ink. When I search online and on amazon it offers pg245. Are these the same and will they both work? Thanks.
My TS3400 Scanner always shows a 1 inch black bar at the edge of documents. It has always done this, but now it also lights half the picture very brightly. Any suggestions appreciated. #pixma 3400
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
