Desktop Inkjet Printers
MG5420 requires excessive head cleaning
MG5420 printer, useage light to moderate, needs its head cleaned a couple of times a week.  Symptoms are streaking and/or missing color in pictures and/or no black pigment printing.  My previous printer, an MP600 which I used for 7 years rarely need ...
edarendt by Apprentice
  • 5480 Views
trouble setting up Pixma MG 7120
I was on the phone with a Canon tech for a couple of hours and still don't have this Pixma MG 7120  scanner working. I notice others have had the same problem.  If you have the problem solved, please tell me what you did.  Which driver did you instal...
Aley_68 by Apprentice
  • 6598 Views
  • 3 replies
MX922 - Can't save PDFs from the printer
I recently purchased a MX922 to replace a Canon MP830.  My primary use is to scan documents and save as PDFs.  Using the 830 was fairly straightforward. My new MX922 is installed direct to the client workstation via USB.  To scan and save a document ...
endorice by Apprentice
  • 9310 Views
  • 4 replies
problem with the print head
I have a cannon pixma 4500 and I get the familiar message the the print head is not installed. I have repedeadly clean the head but this has not fixed the problem. What can be wrong? If the head is useless and I can do nothing to fix it but to replac...
Recently purchased MX459. .
HELP!!!!! My machine is new and I'm so fustrated!!!Is there someone I can call and have him/hercome over to my house to help me. Not good withtalking to computers on phone...grrrrr. Machinesays 'paper jam' and/or load paper - even afterpaper is loade...
swirt by Apprentice
  • 5432 Views
  • 2 replies
MG5300
problem with the printer turning on, it acts like it isn't getting power, but I moved it around the room to different plug, and electric is not the problem.  If you keep playing with it, it will turn on for about 5 seconds then shut off again.  Pleas...
Teri573 by Apprentice
  • 5506 Views
What printer....
....would you recommend?I need it for home use, mainly. I work as a teacher and I print a lot of stuff; but then again, not as much as an office. This would be for my use only.I also prefer it to be wireless (I get tangled in all cables and I can't s...
CanonP by Apprentice
  • 5442 Views
