02-25-2014 08:35 AM
how do i enlarge the print on my ip3600 printer?
02-25-2014 10:38 AM
Hi lou4386!
Welcome to the Canon Forums and thanks for your inquiry!
So that the Community can help you better, we will need to know the Computer Operating System you're using (Windows XP/Vista/7/8 or Mac 10.x), as well as the way you connect to your device (USB or networked via WiFi or Ethernet). It will also be helpful to know the program(s) you're using.
If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team.
Thanks and have a great day!
02-25-2014 01:59 PM
I am connected to win 7 via cable.
03-15-2014 10:35 PM
Hi iou4386,
To enlarge the print coming from your PIXMA iP3600, please follow the steps below:
1. Go to your START menu and select DEVICES AND PRINTERS.
2. Find the icon for your PIXMA iP3600, then right-click over it and select PRINTING PREFERENCES.
3. Click on the PAGE SETUP tab.
4. In the PAGE LAYOUT section of the window, please ensure that SCALED PRINTING is selected. In the SCALING box that appears, if a number smaller than 100% appears, change it to 100%. If 100% is already displayed, select a percentage above 100% (i.e., 110, 125, etc.).
5. Click the APPLY button at the bottom of the window to apply the changes, then the OK button to close out of the PRINTING PREFERNCES window, then attempt to print from the desired program.
Hope this helps!
