Desktop Inkjet Printers
ip2500 pixma - where does this bit go?
Hi Folks, been asked to look at a printer which someone had taken apart to "clean the ink reservoir" and then discovered they couldn't get it back together again.  The case was dismantled, the carriage, ink absorber assembly and absorbent mats remove...
MF2002 by Apprentice
  • 3176 Views
  • 0 replies
"Required Privilege to access scanner"?????
Just installed my Canon MX922 and needed to scan a document.  It says I do not have required privileges to access this folder.  I have Windows 10.I am the only one using this computer and do not use an administrator sign in.  I updated the driver and...
Pixma MG3122 printing problems
Hello.I bought a used Pixma MG3122 printer off Amazon. I'm trying to get it to print properly, but, not having luck.....I installed brand new print cartridges, have kept cleaning, unclogging, and realigning the print heads, but still my printouts hav...
MG5220 is there a 'black only' mode
I VERY rarely print in color. I choose "grey scale" because I do not see a "black only" choice. And yet my printer consumes color cartridges far faster than I would expect using this technique. QUESTION #1 Can I print in "BLACK ONLY" somehow, or QUES...
philr by Apprentice
  • 7261 Views
  • 3 replies
. Insatall the correct printhead
Printer is MG6250  - The printer has had little use and was working perfectly.  Then a message is showing which states ' UO52The type of printhead is incorrect Install the correct printhead." I have taken the ink tanks out but not sure how to remove ...
bekka379 by Apprentice
  • 3698 Views
Canon Pixma printing error
 Hello Canon team,  I am facing this problem while prenting  http://imagizer.imageshack.us/a/img540/7159/YezCuE.jpg I don't really know what happened. suddenly the same line comes repeated several times. above each other.  Please help me.
Zahra by Apprentice
  • 3005 Views
  • 0 replies
Toolbox Not Recognizing Scanner
Greetings, I got a computer from a friend when mine broke. It's running Vista OS. I don't have the disk that came with my Imageclass D480. I downloaded the drivers from Canon. The printer is working. I downloaded MF Toolbox. It's not recognizing that...
Canon MG5400 - manual printing
Hi I have a Canon MG5400 printer and I need to print individual A4 pieces of card. These will not print directly from the paper tray but I was led to believe it is possible to print card manually. I just haven't managed to find out how to do it. Any ...
George2 by Contributor
  • 4898 Views
  • 0 replies
Canon Pixma MG3550
Hi. I have the above printer and am using with a Lenovo Yoga 2 Tablet 830F. Getting error message that print spooler has stopped working. Can you advise? many thanks
hkelly by Apprentice
  • 4379 Views
  • 0 replies
