03-16-2023 06:49 PM
This printer worked for me for like 2 seconds and for the past year I haven't used it because its impossible to connect to it from either my phone or my computer. I am at a complete loss and want to try to reset it to factory default settings and just start over, but even the instructions for that are not applicable. The only ones I have been able to find say to press the "setup" button to start but that button is nonexistant on my printer. Is there another way I can restore it?
03-21-2023 08:28 PM
Hi Surruh311! Thanks for posting in the Canon Community Forum. I see that you would like to restore your PIXMA TS3522 settings back to the factory defaults so you can start the Wi-Fi Setup over.
This printer has a Setup button. The symbol on this button looks like tools (plier and screwdriver). It is located above the Alarm lamp (orange lamp with the triangle symbol) If you need help finding the Setup button on the printer, please visit the following section of the online manual:
https://ij.manual.canon/ij/webmanual/Manual/All/TS3500%20series/EN/UG/ug-160.html
The instructions for resetting the printer’s settings can be found in the following page of the manual:
https://ij.manual.canon/ij/webmanual/Manual/All/TS3500%20series/EN/UG/ug-213.html
If you need help with the wireless setup of the printer, I recommend that you visit the following online articles:
https://support.usa.canon.com/kb/index?page=content&id=ART179739
https://support.usa.canon.com/kb/index?page=content&id=ART180499
https://support.usa.canon.com/kb/index?page=content&id=ART180498
If you still need help, please write back and provide answers to the following questions:
I hope this information helps. Thank you for choosing Canon.
03-21-2023 08:28 PM
03-23-2023 07:48 AM
Thank you so much!! I'm not sure what happened with the connection before but restoring to the factory defaults and starting over worked! I will save this post in case it happens again. Thank you again!
05-11-2023 05:05 PM
Hello. None of these articles state how to factory reset a Canon TS3522. Please write in the comments step by step how to do so I’m extremely frustrated.
05-11-2023 08:31 PM
Hi Whatever2023! Thanks for posting in the Canon Community Forum. I see that you would like to restore your PIXMA TS3522 settings back to the factory default settings. I understand you are getting frustrated.
First, please make sure an error code is not flashing (blinking) in the top right corner of the printer’s display. The error will start with an E or a P. That letter is followed by two numbers. For example, it may be flashing E,0,2 or P,2,2.
You won’t be able to reset the printer if it is displaying an error code. If you see an error, you can try turning the printer off and disconnecting the power cable. If the error code reappears when you turn the printer back on, please write back and provide the code.
If you see a steady number 0 in the top right corner of the printer’s display, you can follow these steps to reset the printer to the factory default setting:
If you need help finding the buttons on the printer, please visit the following section of the online manual:
More information about resetting the printer’s settings can be found in the following page of the manual:
