04-03-2023 05:52 PM
Hello everyone, I am trying to print out some photos and realized that setting the "Print in Color" toggle to off doesn't impact the print. My black ink cartridge is new but the color cartridge is nearly empty, so prints keep coming out weird because it won't print in just black ink. I attached a screenshot of the printer command UI and also of a test print - the super orange side should be in black ink only and I don't know why it keeps using color ink.
I use a MacBook Air. How do I resolve this?
the macOS basic print setup showing the "Print in Color" toggle turned off
the test print showing the photo was still printing in color despite the color toggle set to off
04-03-2023 06:21 PM
I'd like to add that the "Print in Color" swatch works fine for regular printer paper. But I am trying to print on glossy photo paper, not regular paper.
04-03-2023 06:45 PM
What happens if you run a nozzle check?
04-03-2023 07:37 PM - edited 04-03-2023 07:38 PM
As far as I can tell, nothing out of the ordinary. The black ink seems to work fine on regular paper, but not the glossy photo paper. The results are the same whether or not I tell the printer it's got regular paper or photo paper in it.
04-03-2023 07:50 PM
"As far as I can tell, nothing out of the ordinary." Does that mean the nozzle check prints correctly?
Canon Knowledge Base - Printing the Nozzle Check Pattern - TS3120 / TS3122
04-04-2023 07:25 PM - edited 04-04-2023 07:25 PM
I am having the same problem. I have also done all the nozzle and cleaning checks and test. All of them come back completely normal and show no issues, yet the pink problem still exists. I have flushed the tanks too. The problem is only with photo paper and it doesn’t matter if I have it marked as plain paper, it still prints pink while using photo paper.
04-04-2023 10:31 PM
I didn't consider this, thanks! The print did have a couple of lines missing, and running the print head cleaning op helped a but not 100%. Even so, I don't see why that caused this to happen.
I ended up buying different (more expensive) ink cartridges and the prints came out better, but I'm pretty sure it's still printing everything in color even when the switch is turned off. So...I don't know what this is about.
04-06-2023 05:40 AM - edited 04-06-2023 05:41 AM
Even I was facing the same issue but latter discover that the black ink work fine on regular paper, but not the photo paper.
04-06-2023 06:48 PM
That's exactly what's happening with me, which I think I mentioned elsewhere already. Seems like a design problem of some sort that Canon would have to fix, as I don't think it's mentioned anywhere that the printer will sense photo paper is being used and must use color ink on it.
