05-28-2022 05:27 PM
Canon Pixma MX490 powers on and goes through initialization, then powers back off. Keeps repeating the process as long as it's plugged in. Buttons are non-responsive.
05-31-2022 01:58 PM
Same problem here. I used the printer about a month ago and then when I tried to start it this morning it does the exact same thing as described above. I will try the pressing the power button 10x thing, but it looks like that is only temporary. 🤷🏻♂️
05-31-2022 02:09 PM - edited 05-31-2022 03:32 PM
my Maxify MB 2320 is doing the same thing. I made sure it was turned off before unplugging it. When I plugged it back in, it just kept going in an endless power cycle.
05-31-2022 02:10 PM
Im having the same issue . My printer was working last night. Im so frustrated.
05-31-2022 02:30 PM
Same here - nothing works to stop the cycle or fix it. This is most definitely the result of a firmware update push or something on Cannon's side. The likelihood of all of us randomly, spontaneously having this same issue all at once out of nowhere is slim to nil. We need to continue pushing for an actual resolution, not their canned response about upgrading to a new printer. If they just bricked all our printers, they should replace at their cost.
05-31-2022 02:31 PM
I am also having the same power cycling issue. Printer was working fine as of two days ago. Have unplugged several times and still continues once plugged back in. I have also cancelled all jobs sent to printer. I hope this gets resolved...since I just put in two new ink cartridges within the last week!
05-31-2022 02:44 PM
Same exact issue here on my MX492. Can't get it to anything other than "Canon" coming up on the display and restarting. Was printing fine last week....
05-31-2022 02:46 PM
I started the printer without internet access and it started up just fine.
05-31-2022 02:52 PM
How are you getting to not try and connect if the buttons are unresponsive?
05-31-2022 02:55 PM
I unplugged my fiber connection to my modem/router.
05-31-2022 02:56 PM
That “push the power button ten times” trick did not work, for the record.
