05-28-2022 05:27 PM
Canon Pixma MX490 powers on and goes through initialization, then powers back off. Keeps repeating the process as long as it's plugged in. Buttons are non-responsive.
06-03-2022
05:52 PM
02:03 PM
Your satisfaction is important to us, and we apologize for any inconvenience you may be experiencing. A firmware update is available to fully resolve this issue. You can download the firmware update and find easy installation instructions at canon.us/power.
05-31-2022 06:52 PM
REALLY Spooky. Turned off my wireless network and BOOM it starts up... These things are basically bricked unless we can push a firmware fix to them. The support page for it only has drivers from 2021, but just seem like Windows Drivers, and nothing to do with device firmware. I think these are officially bricked.. Cannon should issue ALL OF US new printers unless they can fix them.
https://www.usa.canon.com/internet/portal/us/home/support/details/printers/inkjet-multifunction/mx-s...
05-31-2022 08:06 PM
MX490, same problem. It can't be all of us, but it's infuriating that Canon has not responded with a valid solution.
05-31-2022 08:16 PM
If everyone here is having the same issue with your printer, block you printer from internet access then you will be able to access the display menu and reset the printer and use the printer via a USB connection. If you hook it back up to the wifi, it will start to power cycle again.
05-31-2022 08:21 PM
Fine. But this printer is supposed to function as a network printer. Some businesses use it and now can't print. Typical corporate answers to this problem, which was caused by Canon. I will NEVER buy another Canon product!
05-31-2022 08:29 PM
That's not really helpful if you can't disable the internet. The printer buttons are not responding at all.
05-31-2022 11:00 PM
How do we block it from internet access
05-31-2022 08:25 PM
Italolima has the solution. Search for his reply. It's all about DNS.
05-31-2022 09:41 PM
95% of people who buy this printer have NO tech skills. So that SOLUTION is not applicable. It is Canon's problem to solve, not the users.
05-31-2022 08:30 PM
Same exact issue started today on my MX490. Constant power on shut off loop with only the Canon logo being displayed. Please fix this I need to print assignments for school!!!
06-02-2022 11:07 AM
I changed the IP address of my printer to a made up one and it prints from both my laptop (wifi) and desktop. If you need a valid IP for another reason, see below:
This problem that you are experiencing is because of DNS. I solved my problem by turning off the Access Point (or unplugging the internet cable from the router's WAN port). The printer will turn on normally. Then go to Setup menu > Web service setup > DNS server setup > Manual setup. Configure an IP from your internal network that is not in use or another IP that is not a DNS server, as the printer will not be able to make queries. Once configured, press OK. Select the 'No' option and press OK. Wait a few moments to complete the configuration.
