Pixma MG 7720 only Black ink misaligned
bulaah
My Pixma MG 7720 printer was working fine. I ran out of most of the inks and swapped them out at the same time. Now the printer head is horizontally misaligned- but only the black ink. I did a nozzle cleaning a couple of times, did an auto alignment and a manual alignment. Nothing is improving. It is more noticeable on smaller type. Any insight would be appreciated
3 REPLIES 3
ArthurJ
Could you attach a copy of your nozzle check to your reply. This will help us troubleshoot the issue better.
Attaching one that I scanned. Please advise why I cannot get a better scan. This is a photo scan. I tried a document as well, both at the highest resolution. The rest are phone pics- hopefully you will be able to see the issue. This nozzle check page was just printed out. The page number 3 was printed after I did an auto head alignment. I couldn't find any info on how to interpret it and the type was still off, so I did a manual head adjustment after that. the type still hasn't improved as you can see in the third document that I've attached. Thanks.
You can try and encoder cleaning by using the steps HERE
