11-18-2020
11:19 AM
02:34 PM
I have an iP8720 printer on firmware 1.080 and it says version 2.00 is available. But when I try to update the firmware the printer restart and the website shows unable to load the firmware check manual. Well, the manual says nothing about firmware updates. Does anyone know how I can manually update the firmware?
12-17-2020 02:41 PM - edited 12-17-2020 02:43 PM
Hi burninmedia,
The firmware update of the PIXMA iP8720 is not available on the web site as a download, as it is performed using the printer's remote user interface.
Your PIXMA iP8720 must be connected to your network. Once connected, print the network configuration page to determine the printer's IP address. To print this page, please load plain paper in the printer and press and hold the RESUME / CANCEL button until the POWER lamp flashes white 6 times, then let it go.
On the page that printed, please take note of the IPv4 IP Address.
On your computer, please open a web browser and enter the printer's IPv4 IP Address in the address bar to access the iP8720's remote user interface.
Once that page loads, click on Firmware Update in the menu on the left side to perform the update.
Confirm the update message by clicking Yes and the update will be performed.
I performed this update today, so I know that the update is available and working correctly.
Please note, once the update is complete, the IPv3 IP address of the printer may change.
12-31-2020 11:53 PM
12-26-2025 06:00 PM
I have avoided using the Wi-Fi and networking features of this printer, I simply connect it to my computer via USB to print. Is there a way to just update the printer's firmare while it's connected via USB this way, or is the only way to do it to connect it via Wi-Fi?
12-30-2025 01:21 PM
The printer would need to be connected to Wi-Fi to update the firmware.
03-25-2026 08:43 PM
I have connected the printer to my wifi network and I can print to it from my computer via wifi connection. I got the printer's IP address from the page you suggested printing, and I see that's the IP address my router says is for "Canon." However, I get no response with I try to go to that IP address from multiple web browsers on my computer and iPhone. I have no issues connect to my router via it's IP address from these same browsers. I've tried restarting my printer and no difference. I don't know what else to try. Any suggestions?
