10-21-2025
02:46 PM
10:34 AM
My printer TS9521C doesn’t recognize the ink cartridges. I’ve tried several new cartridges and none of them are making connection.
I have unplugged the printer for hours and restarted it. Gently cleaning the connection…it appears that the cartridge doesn’t touch the connection
please advise
10-24-2025 11:59 AM
Hi! Thanks for contributing to the Canon Community!
I see your TS9521C is not recognizing ink cartridges. You mentioned that you have tried several new ones. I understand you have also left the printer's power cable disconnected for hours before restarting it, and you've gently cleaned the connections.
So I can get a clearer picture of what may be happening, I will need some more information and perhaps some photos. However, I would recommend that you contact Canon support. If you haven't done so, you can create a My Canon account and register the printer. Once you've done that, you can call toll-free 1-800-652-2666 to speak with a support representative.
You can log in or create your My Canon Account at this website:
https://myid.canon/canonid/#/login
If you need to create a new link after opening the above page, click on "Don't have an account?" at the bottom of the window.
So that we can continue helping you here, please write back. Please attach the following photos to your reply:
It will also help if you can provide us with the error code/ message that is being displayed on the printer once you close the cover (after installing the inks). The code should be four characters long. Examples of possible codes are: 1401, 1600, 520E.
If you cannot attach the above photos to your reply, I recommend that you make sure you are using cartridges that have the number 281 and 280 on them. They should also be installed in the following order (from left to right):
You should also review the instructions for installing inks and make sure you are following those steps. Here is a link to the manual page with the instructions:
https://ij.manual.canon/ij/webmanual/Manual/All/TS9500%20series/EN/UG/ug-127.html
If the you are using the 281/280 cartridges and they are in the correct order, I recommend creating a Canon account, registering the printer, and calling the toll-free phone number previously mentioned.
I hope this helps. Thanks again.
