Photos scanned on Canon TR7620 preinter come out as PDF and not JPEG
Eldergeek60
This is a recent problem with the scanning of photos.  I scan directly from the printer and every scan comes back as PDF file.  I have used the IJ scan utility but would rather scan directly from the printer. Any ideas?
4 REPLIES 4
janeintoronto2
Sorry I have no answer.  I just wanted to add my frustration about the change in default to .pdf from jpeg.  I too, use the IJ Scan utility and I have to keep changing it to jpeg.
On this model, you cannot change then set the default file type from .PDF to .jpg when scanning on the printer.  It has to be selected each time scanning is performed.  You can however set the default file type as .jpg using the IJ Scan Utility.
Instructions for doing that can be found here:
Save Settings Dialog Box - IJ Scan Utility (Win) https://share.google/pPpL1oh4RMr4z3ffx
janeintoronto2
I'll give an upvote, though I'm having a hard time reading the page you refer to.  But hen, I dont have the scanning app open.
I had the same problem. I used the scan utility app. However I have also realized that by pausing my VPN it solved the problem.
Hope this helps.
