PIXMA TS8320 How to print using only black ink on a Mac? Impossible?
armandhammer
This is a very specific problem. Please read this thoroughly, as I'm sure many of you will misunderstand what I am asking.
Printer: PIXMA TS8320
Computer: Mac running OS 10.15.4 Catalina
Problem: When I select "Black and White" printing, the printer still uses the color ink cartridges. So even if I NEVER select to print anything in color, my color cartridges become depleted. To be clear, the documents are printing in monochrome, not color -- but the printer is mixing color inks to achieve black and grey tones.
When I print the same documents to the same printer from my Windows PC and select "Print as grayscale" NONE of the color ink is used. I am verifying this with a microscope. On documents printed from Mac, it's very clear that the "grey" is actually made up of a bunch of tiny color dots. On the ones printed from Windows, all of the dots are black.
So this is somehow a problem particular to Canon's current Mac printer drivers. Note that older instructions on how to fix this issue do not work. I called Canon and they said they are aware of the issue, but that it's up to Apple to fix it -- according to the Canon support rep, Canon only provides printer hardware details to Apple and it's actually Apple that writes the drivers for Canon printers. I filed a bug report with Apple months ago but they have not responded.
Does anyone have a solution that works with my printer on the latest version of Mac OS? Right now I'm having to print all of my black and white documents (90% of what I print) using Windows, which is really inconvenient.
Canon really needs to accept responsibility that they are shipping printers that don't actually do true Black and White printing when hooked up to a Mac. They should develop alternative drivers for Mac users to install that work properly, as Apple's drivers included with the OS are faulty when it comes to black and white printing.
7 REPLIES 7
jrhoffman75
Hello. Welcome to the forum.
Have you downloaded the March 2020 Setup software for the printer?
I just checked some more (original color) test prints in B&W and they no longer show the color dots. It's all black now. When I first bought this printer back in February I had the "printing in b&w uses color inks" issue and only now got around to posting about it. Maybe a recent Mac OS update fixed it?
Hello, I have the same problem, I can't get my mac to use only black ink.
Where do I download this setup software from?
Thank you.
How did you solve it?
Hi, adrianaestivill!  You can download the latest driver and software for your PIXMA TS8320 right HERE courtesy of our friends at Canon Canada.
Hope this helps!
frost_journey
For me the thing that finally worked is unchecking and then checking again this "Black & White" option (check out this screenshot). My mac OS is 12.2.1 (Monterey)Screen Shot 2023-09-02 at 8.10.55 PM.png
martingolding
This is not specific to just one printer, I have recently changed printers and have the same issue. Printing from windows is fine, but any apple device is unable to print with any amount of control; Either it is not possible to print black ink only, or randomly with ios devices, they will always try to use the rear tray for printing images.
Holiday
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R5C - Version 1.1.1.1
EOS C80 - Version 1.0.3.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
