12-01-2025
08:56 AM
09:30 AM
I just bought a Canon Pixma TS6520 which says has 1200 x 2400 dpi. When I open up the basic scanner controls, the highest dpi I can input is 600 dpi, not any increment higher. I wanted to scan some old photo for enlargement that would require a higher resolution.
Is there other program I should use to scan at 1200 or 2400 dpi?
I still have 3 weeks to return it...
Thanks!
12-01-2025 09:46 AM - edited 12-01-2025 09:47 AM
Image garden scan and scan utility only scans to 600 dpi. Use the Scan Gear program (which is on the scan utility panel) and you can set the scanner to 1200 dpi.
12-01-2025 10:03 AM
What operating system version and build are you using the printer with? How is your printer connected and to what?
Which software drivers and utilities did you install? I'm including a link to the product's support portal so you can give us specific information.
https://www.usa.canon.com/shop/p/pixma-ts6520
We may have additional questions based on your responses.
12-01-2025 11:34 AM - edited 12-01-2025 11:48 AM
This may simplify the settings for you if you have the software installed for windows, if not you can get it here, USA support does not have this on their site due to some error I think, look for the download button on the page:
https://canada-canon.my.site.com/customersupport/article/0101270017
to set the scanner resolution to 1200 dpi on your PIXMA TS6520, follow these steps:
Turn on the Printer: Ensure your PIXMA TS6520 is powered on.
Select Scan: On the operation panel, choose the "Scan" option.
Access Scan Settings: Look for the "Scan settings" option and select it.
Set Resolution:
Confirm Settings: After setting the resolution, confirm your settings to proceed with the scan.
Open Canon IJ Scan Utility: Launch the software on your computer.
Select Document Type: Choose the type of document you are scanning.
Adjust Settings:
12-01-2025 05:05 PM
I'm using a wifi connection to the printer scanner, and on my PC (windows 11) I'm running the only software that was automatically installed when connecting my printer. It is called Canon Print. The cannon support web site provide a downloadable application only for iOS and Android.
12-01-2025 05:07 PM
Thank you for the link. I'll give it a try.
12-01-2025 10:03 PM
The link I posted provides windows 11 drivers and all compatible software
